Bolt On Fuel Pump - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-22-2009, 07:27 PM Thread Starter
Date registered: Sep 2007
Bolt On Fuel Pump
Trying to get this bolt off of the fuel pump.
Used two wrench to counter turn in attempt to loosen the hex bolt at the bottom.
Is this correct?
Not sure if it's not loosening up because it's locked up or if I'm doing it wrong.
Satyricon is offline
post #2 of 4 (permalink) Old 07-22-2009, 08:36 PM
wbain's Avatar
Date registered: Dec 2003
Loosen the top bolt for the pipe. Use penetrating oil too.
wbain is offline
post #3 of 4 (permalink) Old 07-22-2009, 08:46 PM
Date registered: Apr 2008
Quoted: 2 Post(s)
For now hold bottom one stationary. Turn top "B" nut counter clockwise. Remove the fitting and tube. Remove the pump. After you've removed the pump you can easily remove (counter clockwise again) the remaining fitting in the pump. As wbain said, use penetrating oil on the fitting to make the job easier. Before reinstalling fittings on new pump inspect for galling, thread damage, cleanliness, etc.
mbbuff is offline
post #4 of 4 (permalink) Old 07-23-2009, 06:47 AM Thread Starter
Thanks to you both - greatly appreciated.
    Adjusting bolt for power steering pump Bev W123 E,CE,D,CD,TD,TE Class 5 09-18-2008 11:33 AM
    Power Steering Pump Bolt fastroubaix W123 E,CE,D,CD,TD,TE Class 0 08-18-2008 11:08 AM
    Little adjuster bolt near water pump rob76 W124 E,CE,D,TD Class 11 06-28-2008 08:29 PM
    water pump housing bolt cashman W123 E,CE,D,CD,TD,TE Class 0 08-23-2006 09:45 PM
    last bolt on water pump housing TMN G-Class 3 10-29-2001 03:54 PM
