Synching Carbs - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-20-2009, 06:39 PM Thread Starter
Date registered: Sep 2007
Synching Carbs
I'd like to learn how to synch and adjust my Zenith Carbs. Had them rebuilt and synch'd a year and a half ago and have since put less than 200 miles on. But it's been suggested that they get adjusted.
I know I need a unisync and this link seems to present a clear guide for calibration.
I can usually crack a manual and figure it out, but knowing how complicated the carbs are I'm wondering if this is reccomended from senior members. It looks like I can do it, but assuming this is typically my first mistake.
Satyricon is offline
post #2 of 3 (permalink) Old 07-20-2009, 07:39 PM
Date registered: Apr 2008
Quoted: 2 Post(s)
Why do you think they need to be re-synch'ed? Did the rebuilder not do it right? Once done "correctly" they should never have to be done again, unless someone messes with something. Example: My Dad bought a new 250S in 1967. It was given to me when he passed, and I have now given it to my son. It has never had to have the Zenith's re-synch'ed and, so far, all carb. work needed has been done without having to remove them. Good, dependable units, IMO.
mbbuff is offline
post #3 of 3 (permalink) Old 07-21-2009, 07:06 AM
Date registered: Jan 2007
Quoted: 85 Post(s)
Good advice
If your carbs were properly sync'd when you had them rebuilt, and they are now out of sync, something else is wrong. Likely culprits are a vacuum leak or a plugged idle circuit on one carb.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
    Bluetooth iPhone Synching Chlleneges jordanb W245 B-Class 2 03-17-2009 03:50 AM
    Bluetooth iPhone Synching Chlleneges jordanb W245 B-Class 0 03-16-2009 07:00 PM
    Synching the Clocks Darkmann W163 M-Class 7 10-10-2006 06:39 AM
    my carbs again .... Fizz Unimog 3 08-15-2005 10:19 PM
    Weber carbs MB250 Vintage Mercedes-Benz 9 09-15-2004 12:09 PM
