Minor (I hope) engine issues - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-19-2009, 11:00 PM Thread Starter
Date registered: Jul 2009
Vehicle: 1965 Mercedes Benz 230s
Post Minor (I hope) engine issues
After about 2 months at the mechanics, I have finally got my beloved 1965 230s back on the road.
A culmination of events (lost keys/broken suspension) led to the car sitting idle for too long and the petrol going off in the fuel system. My mechanic had to remove, clean and reskin the fuel tank, and replace the carbeurators (cleaning out the fuel lines etc along the way).
It is (generally) running better than it ever has now.
However there are a couple of side effects of this overhaul.
The is now a petrol smell in the car which I can only get rid of if I drive with the window down.
Also the car appears to be misfiring every now and then when I accelerate - it didn't do this before from memory.
And finally every now and then (once an outing) I get a puff of white/blue smoke when I accelerate from a stationary position (though not when I first start the car).
Does anyone have any advice on these issues? Have some things been missed/forgotten by the mechanic when they were doing the carbs?
Thanks
douwi230 is offline
post #2 of 6 (permalink) Old 07-20-2009, 03:23 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Sounds like they misadjusted something. I'd check timing first, but my knowledge of carb'ed cars is scant. Does it smell like it's running rich? Have you checked the plugs?
Grubeguy is offline
post #3 of 6 (permalink) Old 07-20-2009, 11:32 AM
mbz114's Avatar
Date registered: Apr 2009
Vehicle: 1972 Mercedes-Benz 250C
Another thing you might want to check is if the muffler is still ok. Mine had asimilar problem that you smelled gas in the car and we had the muffler changed and now you don't smell gasoline in the car
mbz114 is offline
post #4 of 6 (permalink) Old 07-21-2009, 05:21 PM
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
A great way to clean out varnish is to put a quart of acetone in your fuel when you fill up next, or a pint to a half. It appears that you are having 'varnish boogers' get in the fuel lines now and then.
renaissance_warrior is offline
post #5 of 6 (permalink) Old 07-22-2009, 10:45 AM
Grubeguy's Avatar
Quoted: 99 Post(s)
I'd also recommend you drain your tank and flush both the lines and tank.
Grubeguy is offline
post #6 of 6 (permalink) Old 11-01-2009, 01:51 AM Thread Starter
So it turns out the carburetor hadn't been tuned properly by the guys that reconditioned it. I sent it back to them to re-configure.
Thanks for all your thoughts.
douwi230 is offline
    Minor electrical issues ae35@shaw.ca W124 E,CE,D,TD Class 1 06-07-2009 08:07 PM
    Minor electrical Issues ae35@shaw.ca W123 E,CE,D,CD,TD,TE Class 1 06-07-2009 07:45 PM
    Some minor W126 issues... Richard / E320 W126 S,SE,SEC,SEL,SD,SDL Class 9 05-23-2008 01:55 PM
    Help with Minor(hopefully) issues with a C230 K murtazac W202 C-Class 2 02-26-2008 09:53 PM
    Minor Issues tiger2doll W163 M-Class 3 10-03-2004 01:42 PM
