'78 280CE runs rough after warmed up - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 07-18-2009, 12:14 PM Thread Starter
Date registered: Jun 2009
Vehicle: Mercedes 280CE
I've had the oil changed, i even tried the 10w40 oil for older cars, i've changed the spark plug wires, the air filter, and i don't think the vacuum is leaking.
once my car is warmed up, especially if it's a hot day, the engine will shake a bit and sometimes the car will stall when stopped at a light. i often have to put it in neutral and give it a little bit of gas at stop lights if i've driven it for a little while and the car has warmed up.
it also doesn't go well from highway driving to city driving.
any ideas?
OHMS_BURN is offline
post #2 of 9 (permalink) Old 07-19-2009, 05:19 PM
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Quoted: 2 Post(s)
what kind of plugs did you use?
'79 280CE with 226,000 miles
'76 240D 4 speed with 190,000
'85 300D Turbo with 266,000 miles
GONE but not forgotten
'76 300D with 195,300 miles
"83 300D with 174,000 miles
79Mercy is offline
post #3 of 9 (permalink) Old 07-19-2009, 05:40 PM
benzmizer's Avatar
Vehicle: 1983 240d AT; 1993 e320 AT
Quoted: 4 Post(s)
Stewart, it seems that he only replaced the spark plug wires. Could be a case of a dead spark plug.
benzmizer is offline
post #4 of 9 (permalink) Old 07-19-2009, 09:45 PM Thread Starter
i hope that's all it is...
today it was worse. i drove for a while and the car started to lose acceleration going up a hill. i managed to get it back, but it did backfire once. then it wouldn't start up again. i'm wondering if too much gas is being sent into the engine.
post #5 of 9 (permalink) Old 07-20-2009, 02:25 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
Check your plugs - you'll have significant fouling if it's too rich...
Grubeguy is offline
post #6 of 9 (permalink) Old 07-25-2009, 03:44 PM Thread Starter
OK. the plugs were the problem for it losing engine power, but i'm still having trouble with a rough idle after the car is warmed up. the car shakes and sometimes stalls at lights once it is hot. what could this be?
post #7 of 9 (permalink) Old 08-06-2009, 05:46 PM
pidgy999's Avatar
Date registered: May 2008
Vehicle: 1980 280ce
Send a message via AIM to pidgy999
I had that problem when I first got my 1980 280ce. It just required an adjustment of the mixture screw and idle screw. Other areas to check would be your warm up regulator, fuel filter, fuel pump...
pidgy999 is offline
post #8 of 9 (permalink) Old 08-08-2009, 04:53 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
Run a can of 44k in the gas, you have injectors spraying improperly. A thread, not a cone. A common problerm.
renaissance_warrior is offline
post #9 of 9 (permalink) Old 08-16-2009, 07:39 PM
Edited to add, that vacuum connections and old important rubber lines are enemies of proper mixtures. Leaks suck, literally.
    78 280CE stall after warmed up, after highway driving / upstate NY repair? OHMS_BURN W123 E,CE,D,CD,TD,TE Class 4 06-14-2009 09:29 AM
    engine runs bad when warmed up (fine cold) obakesan W124 E,CE,D,TD Class 2 08-02-2008 11:33 PM
    F/S 1979 280ce runs and drives xskye For Sale/Wanted/Trade/Giveaway 2 05-17-2007 10:29 PM
    Rough idle when warmed up Brasilia Flyer W126 S,SE,SEC,SEL,SD,SDL Class 5 07-17-2006 09:33 PM
    Runs rough Jippi W201 190-Class 0 10-25-2004 01:05 PM
