65 220 S Stalls at low idle - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 07-13-2009, 08:07 AM Thread Starter
Date registered: Sep 2007
Morning - My 65 220s is stalling at low idle. If I give it gas it's OK - as soon as I release to idle it putters and stalls after a few seconds. Carbs we're recently rebuilt, they open fine. Air filters not the problem, pulled it out and it's still stalling.
I'm wondering if it's a fuel line issue? Possibly the filter?
Any suggestions greatly appreciated.
Satyricon is offline
post #2 of 9 (permalink) Old 07-14-2009, 08:15 AM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
Probably the carbs need to be syncronized and/or the mixture adjusted. Rebuilt doesnt mean calibrated, lol.
renaissance_warrior is offline
post #3 of 9 (permalink) Old 07-19-2009, 11:32 AM Thread Starter
Thanks for the reply. Had the carbs synch'd about a year and a half ago, could be the problem.
post #4 of 9 (permalink) Old 07-20-2009, 09:12 AM
Richard 220Sb's Avatar
Date registered: Jun 2006
Vehicle: 1964 220Sb Fintail
My '64 tends to suffer a similar problem if I dont use the car for a couple of months. Tweak the carbs ad she's fine. Best solution as always is to use the car as much as possible.
Richard 220Sb is offline
post #5 of 9 (permalink) Old 07-20-2009, 08:02 PM
Date registered: Apr 2008
Quoted: 2 Post(s)
I responded to your other post regarding re-synching. Now I see why you want to do it. Has this problem existed since the carb. rebuild, or is it something more recent? Do you have a way to check idle RPM? It could very likely be as simple as an idle speed, and/or idle mixture adjustment. I wouldn't jump into re-synching until I have verified those items are set correctly, especially if everything was working properly after the rebuild. You may also want to check for vacuum leaks. Are the plugs, points/condenser, ignition wires, cap and rotor all in good order? Are the timing and dwell angle set correctly? Have any of these items been recently changed and/or adjusted? Is it hitting on all cylinders at idle? At higher RPM?
mbbuff is offline
post #6 of 9 (permalink) Old 07-21-2009, 06:47 AM Thread Starter
Thanks for the feedback.
Taking your advice from your response on the carb synch post - I'm not going to touch them, except to adjust mixture. I had the Mechanic check compression and points, leaks, etc when I first bought the car. Sent it back with a clean bill of health. I had the carbs completely cleaned and rebuilt and synch'd a month later - they haven't been touched since.
I need to check the timing when I get the new fuel pump in.
Thanks for your suggestions. A lot to work from.
post #7 of 9 (permalink) Old 07-21-2009, 07:18 AM
Date registered: Jan 2007
Quoted: 82 Post(s)
One quick check is to remove the air cleaner and locate the idle air opening on the top of the carbs. It's a small hole, I think by a bump in the top cover. Hold the throttle so the engine will barely stay running, and plug the hole with your finger or a pencil eraser on each carb and see if it makes a difference. If it doesn't, then that carb's idle circuit is probably plugged.
A second check is to again hold the throttle at a point where the engine will just run, and look down the carbs. If you see gas dripping from the feed tube, then you have a vacuum leak in that carb.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #8 of 9 (permalink) Old 07-21-2009, 10:43 AM Thread Starter
Thanks for the advice. I'll try this out. Need to swap put the fuel pump first.
A friend suggested hitting the base of the carb with Carb cleaner. Tested this over the weekend and didn't notice a difference - will try your method as well. Sounds more reliable.
post #9 of 9 (permalink) Old 07-21-2009, 06:54 PM
Quoted: 2 Post(s)
Ctaylor738 makes a good call. If the idle air bleeds are restricted/plugged, it can cause all kinds of grief with the idle quality. If the carbs. were recently done properly this should not happen though. They are located on the carb. top on the choke side. Should look like a small brass jet. Also, what's wrong with the fuel pump?
You may want to reference this site for a little more info. on your carbs. It's not all inclusive, but may help a little.
The Zenith Carburetor: The MB Adjustment Manual
mbbuff is offline
    low idle speed, stalls at stop sign satrat W202 C-Class 59 09-23-2009 06:43 AM
    Engine stalls when warm - 1964 220 SEb DavidT Vintage Mercedes-Benz 8 09-06-2007 02:47 PM
    low fuel(quater of a Tank) = rough idle and stalls S3201994 W140 S-Class 6 02-05-2007 06:11 PM
    230TE stalls at low speed Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 7 06-18-2002 12:34 PM
    260e low idle stalls on first start Guest (MBNZ) W124 E,CE,D,TD Class 0 03-14-2002 06:57 PM
