Weber Carbs Leaking Gasoline - 190SL - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-09-2009, 04:02 PM Thread Starter
Date registered: Jul 2009
Hello. I'm new to this site, and have a question I hope someone can help with.
I'm working on a '59 190SL, and have managed to get the car started but the Weber carburetors are leaking gasoline out of the air-intake barrels.
I had a mechanic friend look them over, and he cleaned them up but did not do a "rebuild". I reinstalled them, but the same thing is happening - there's quite a bit of gas coming out and going directly on to the manifold. (The car was not run for several years, by the way.)
Has anyone heard of this, or experienced the same thing? The carbs were originally purchased and installed in the early 80s, and were working fine the last time the car was running. It's been at least 2-3 years since that happened however. Any input is welcome, and thank you for your time in advance.
stevaroo is offline
post #2 of 4 (permalink) Old 07-09-2009, 04:47 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
Sure sounds like stuck or leaking needles and seat, or sunken floats.
renaissance_warrior is offline
post #3 of 4 (permalink) Old 07-09-2009, 09:19 PM
wbain's Avatar
Date registered: Dec 2003
The original carbs are Solex sidedraft carbs, similar to Webers.
::: International 190SL Group :::
and a repair gallery:
wbain is offline
post #4 of 4 (permalink) Old 07-12-2009, 04:15 PM
Vehicle: 1964 Mercedes 220Sb
These carbs are really easy... I had the same problem and it turned out the guy the people who had the car before me paid to rebuild the carbs, had cut the gasket too big and it was interfering with the float's ability to float... I cut a gasket to actually fit it correctly and it works like a charm...
tgikal is offline
    GASOLINE LEAKING WHEN I FILL UP THE TANK! PLEASE HELP ASAP deyainrdy4ds MB Safety & Testimonials 1 09-23-2007 08:06 PM
    Leaking gasoline in front of right rear tire!!! MBENZ1987 W140 S-Class 12 11-26-2006 09:38 PM
    my carbs again .... Fizz Unimog 3 08-15-2005 09:19 PM
    Weber Carbs. MB250 Vintage Mercedes-Benz 4 06-20-2005 10:22 AM
    Weber carbs MB250 Vintage Mercedes-Benz 9 09-15-2004 11:09 AM
