1964 220Sb Stalls when put in gear - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 07-08-2009, 10:51 PM Thread Starter
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
Question 1964 220Sb Stalls when put in gear
About a month ago I bought a 1964 220S automatic-trans, dual zenith carbs, straight six, it leaked gas and didn't have brakes... but it ran...
So far I've seemingly gotten the master cylinder working (can't get a rebuild kit so I made my own seals) and bled the brakes, replaced a gasket in one of the carburetors so it no longer leaks gas. now it starts and stays running fine. I left it running a good 20 minutes in park without any help (revving) so it idles cold and warmed up.
The problem I'm having now is when its put in drive or reverse it jumps a little and stalls. Also, pressing the brake pedal causes the idle to drop and a hissing noise can be heard from inside the car.
I'm obviously leaning towards a vacuum leak but I don't know where to look.
Any ideas?
tgikal is offline
post #2 of 9 (permalink) Old 07-09-2009, 09:33 AM
Brake booster leaking, get a good used one
Brian O
bostosh is offline
post #3 of 9 (permalink) Old 07-09-2009, 03:48 PM Thread Starter
My friend suggested a tranny or rear end problem, so when I get around to it I'll put the back wheels up on stands and try putting it in gear... see what happens... only get Monday, Tuesday, and Wednesday to work on it right now...
tgikal is offline
post #4 of 9 (permalink) Old 07-22-2009, 11:59 PM Thread Starter
The wheel spun fine after a awkward clunk so I think the tranny and rear end are fine...
I just installed a new brake booster and the brakes work good when its running (park or neutral) still stalls if I put it in reverse or drive, but I think I got it down to a carburetor problem... When it was at a low point in idling speed I put it in gear and it stayed running and moved until I took my foot off the gas... it goes high and low.. turn down the idle and it stalls so its idling too high to be put in gear... they probably need tuned like mad..
The carbs should be clean, but I don't have much faith in the guy that cleaned em 2 years ago (had to fix one of his gasket jobs already)... so I'll probably get some rebuild kits and see If I can get em cleaned and synced up...
Then all I'll have left is a power steering pump problem...
tgikal is offline
post #5 of 9 (permalink) Old 07-23-2009, 04:33 AM
wbain's Avatar
Date registered: Dec 2003
There is a lot of information at the top of the forum. Look at this post and the Zenith Carb link. It shows how to adjust them.
http://www.benzworld.org/forums/vint...resources.html
wbain is offline
post #6 of 9 (permalink) Old 07-30-2009, 10:50 AM Thread Starter
Found several clogged holes and broken diaphrams during the rebuild, the mixture screws were broken and dirt in a jet....
so I fixed quite a bit with the rebuild kits and a spare carb I picked up at a junk yard for $50
put the carbs back in tuned the way the service manual said to (when just about to open give the idle screw one half turn, mix screws out two turns)
The results are exactly the same... wont stay at a steady idle, except it dies when warm now...
I'm really hoping this is only a adjustment problem...
tgikal is offline
post #7 of 9 (permalink) Old 07-30-2009, 01:17 PM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
Sounds like the timing is off in the distributor. Will idle but will not drive?
Ed Mclass is offline
post #8 of 9 (permalink) Old 09-20-2009, 08:49 AM Thread Starter
Well now the car drives and it idles for the first 5-10min until it get warm then it still stalls out
plus I was wondering what to expect for the shifting
it says its a 4-speed auto, 1st is the passing gear so it starts in 2, at about 15mph shifts to 3, and about 35mph shifts to 4... then 4 all the way to 80mph? engine is pretty loud at 70 just wondering if thats normal
tgikal is offline
post #9 of 9 (permalink) Old 09-20-2009, 09:56 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Loud engine noises at 70 are normal, especially at the RMP it runs. Would you say there's tapping, knocking or otherwise unusual engine sounds? If you still hear a clunk when you shift into gear, I'd suggest looking at your drive shaft flex disk or the universal joints...
Grubeguy is offline
    ML320 stalls when put in gear... Chevota W163 M-Class 13 10-15-2009 09:54 PM
    LOTS of smoke, stalls in gear pinkshinyalan W123 E,CE,D,CD,TD,TE Class 17 08-20-2009 07:22 PM
    1985 500 SEL stalls when put in gear. 79blackmalibu W126 S,SE,SEC,SEL,SD,SDL Class 3 04-04-2008 04:59 PM
    Engine stalls when warm - 1964 220 SEb DavidT Vintage Mercedes-Benz 8 09-06-2007 02:47 PM
    85 190E 2.3 stalls when put in gear jaguarnaut W201 190-Class 7 10-09-2005 02:55 PM
