Radio for a W114 250 - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 07-08-2009, 01:25 PM Thread Starter
mbz114's Avatar
Date registered: Apr 2009
Vehicle: 1972 Mercedes-Benz 250C
Question Radio for a W114 250
What size new stereo would fit in the same place the old Becker radio did in a 1971 250 sedan? Also does anyone know of a company that makes new radios that sound good and still look like the classic ones, the radio doesn't necessarily have to look an old Becker one
Thanks,
Brandon
mbz114 is offline
post #2 of 10 (permalink) Old 07-08-2009, 01:52 PM
Date registered: Jun 2009
Vehicle: 1972 350SL 4.5, car #917
Quoted: 2 Post(s)
tdskip is offline
post #3 of 10 (permalink) Old 07-08-2009, 04:42 PM
Vehicle: 2005 C350, 2002 ML270CDI, 1969 230S, previously 2002 A160, 1985 380SEC ivory, 1983 380SEC grey
Hi mbz,
the size of the cut out is the same as what is now known as a one unit DIN, so almost any modern radio /CD /mpeg woudl fit. the problem is the loudspeakers. the car originally had a small low powered approx 7"x3" elliptical speaker fitted behind the grille in the top of the dashboard. A few cars I have seen have cut into the back parcel shelf and fitted 9"x6" speakers there, but the sound is then behind you.
It is difficult to see where to put speakers in the front of the car without hacking it around too much, but speakers in line of sight to the listeners' ears would provide a reasonable stereo image, etc.
All in all a tricky problem. I had thought of mounting small bullet tweeters at the base of the windscreen pillars, and larger speakers in the side trim under the dash, but I want to keep my car looking as original as possible, so I haven't actually done it yet. :-)
regards
David
Audiophile_AU is offline
post #4 of 10 (permalink) Old 07-09-2009, 12:23 PM Thread Starter
mbz114's Avatar
David, mine actually has some speakers under the dash on the panels toward the outside of the car on each side.
Also thanks tdskip for the link i would use the radio but i'm afraid it won't work ideally in a car here in the US and on top of that i don't know if i could even get one from the UK. Thanks for the link
mbz114 is offline
post #5 of 10 (permalink) Old 07-27-2009, 10:09 AM
robgigliotti's Avatar
Date registered: Feb 2009
I had a problem with the original radio and it was a fortune to get it fixed so I got a cd player from Ebay, took the glovebox out and chopped a hole in the back of it to fit the new radio in. I put a set of speakers under the dash on either side and it works a DANDY!! I have the old radio look but a digital tuner in the glovebox.
______________________________
1984 300sd -
1969 220d -
1997 Chevy Suburban -
robgigliotti is offline
post #6 of 10 (permalink) Old 07-28-2009, 11:34 AM
Joshua Lomax's Avatar
Date registered: Jul 2009
Vehicle: 1972 250 saloon
Post same problems...
i have the same problem...
i have a '72 250 and someone has put an aftermaker tape player from the 80's in it. when i bought the car it didnt work so i did some research....
somehow.... they have it wired into the original amplifier but the wire coming out the amplifier has been cut.
the whole amp was just laying in the floor when i bought it and the guy said he didnt know what it was.
there is also a wire coming from the tape player/amp area that goes underneath the drivers dash and almost out the firewall but it has been cut.
i have no idea what wires are going where and why it looks like this.
i need some real help.
also any idea on where to get a CHEAP becker europa? ebay is ridiculus
Joshua Lomax is offline
post #7 of 10 (permalink) Old 07-28-2009, 12:14 PM
I took the plug from the back of the hazards and found which one was going to be hot with the key and wired my cd player to that ( had to use a little extra wire to get it to the back of the glovebox). I totally did without the factory radio, just unplugged it. I think thats where I had a lot of problems, that amp. I just did away with it, Its still in there and that little plug is just zip tied to something else. I will take some pics this week, I havent driven that car in a week or so, Im due for a drive...
1984 300sd -
1969 220d -
post #8 of 10 (permalink) Old 07-29-2009, 11:38 AM
Post bypass
so i can bypass that amp altogether? what about the original speaker plugs?
should i splice into the originals?
im so confused!
post #9 of 10 (permalink) Old 07-29-2009, 12:34 PM
Just find yourself a set of speakers and maybe some extra wire. Totally forget about that amp if you are putting a different radio in there. Unless there are already speakers in the vehicle you are going to need some of them as well. Find yourself a wire behind the center console that is going to be hot when the key is on, and a good ground. Wire that up and add speakers, viola!! The hole that the old radio came out of is the same size as newer radios. Its an easy install..
1984 300sd -
1969 220d -
post #10 of 10 (permalink) Old 07-30-2009, 01:29 PM
Post ??
since the aftermarket has been unplugged should i try to use those speakers? as far as i know all the speakers are there and work, never heard them but i can see them, i can tell it was professionaly installed.... all the wires are REALLY short!
i willl update when i find out more....
    W114 Chassis, 1969 250 C with 5 speed 67300se5spd For Sale/Wanted/Trade/Giveaway 1 06-23-2007 09:58 AM
    Found a 250, W114 barberhauler Vintage Mercedes-Benz 2 06-19-2007 06:40 AM
    W114 71 250 Engine Question AndyD Vintage Mercedes-Benz 2 10-03-2006 08:40 AM
    Got a 71 W114 250 today Nutz 4 Benz Vintage Mercedes-Benz 15 10-05-2005 11:16 PM
    mercedes w114 250 2,8 -74 Guest (MBNZ) General Mercedes-Benz 1 03-02-2001 04:37 PM
