W 111 or W110? - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 07-18-2009, 11:41 PM Thread Starter
Benzicon's Avatar
Date registered: Feb 2009
Thanks so much Erik, feerocknok, KCM and wbain, but the previous owner says its has never been touched nor changed/renovated the car. The serial numbers stamped in front of the radiator cant be seen by now due to corrosion, but I'l try my best to restore it so we can decipher the numbers. It seems the numbers are in excess of twoo digits according to benz guide on serial numbers. But I'm pretty sure, this sedan is a mix of W111 and W11o features. fenders and headlights are all original and intact plus the double bumpers, and fintail chrome trims that we see in W111.
KCM, what youve seen in the interior picture ( horn ring ) is my other W110. I'l upload more pictures of this "hybrid" benz that I found. This mix has a diffrent horn ring from the 1965 W110-colored dark green. Thanks
Benzicon is offline
post #12 of 16 (permalink) Old 07-19-2009, 01:10 AM Thread Starter
Benzicon's Avatar
W111 or W110?
More pictures uploaded in my gallery.This sedan I am referring is colored light blue. Thanks.
Benzicon is offline
post #13 of 16 (permalink) Old 07-22-2009, 01:34 PM
Date registered: Jun 2004
Quoted: 17 Post(s)
I definitely think it is a 1965 to 1967 200 that somebody fancied up with W111 trim plus some. The previous owner may have never made changes, but somebody before him did.
Did you ever look for the serial number on the frame rail below the air cleaner? This is the number I would take as gospel as it is stamped directly into the chassis. Data plates can be changed.
KCM is offline
post #14 of 16 (permalink) Old 07-23-2009, 01:11 AM Thread Starter
Benzicon's Avatar
Thank you very much. I'l look into that detail and feed it back to you the soonest.
Benzicon is offline
post #15 of 16 (permalink) Old 12-01-2010, 01:42 AM
Date registered: Apr 2010
it's a w110 not a w111
it's a w110 not a w111 , it's simple . look to the head lights.
w111220s is offline
post #16 of 16 (permalink) Old 12-06-2010, 09:52 PM
baltobenz's Avatar
Date registered: Jan 2007
Vehicle: 1966 300se coupe
It's a 110 with 112 chrome added
The most important difference between the 110 and 111 is that the nose of a 110 is shorter from the front edge of the front doors forward. The rest of the basic 110 and 111 bodies are identical. 110s were originally only four cylinder diesel or gas. In '66 and 67 they stuffed a 2.3 liter six into the 110 and called it a 230. This was accomplished by moving the radiator forward and inside the cowl to make room for the bigger engine. There was a remotely mounted tank to fill the radiator, as in the 230sl.
All 111 and 112s were sixes. which is why they required a longer nose.
The bumpers are 111 or 112 as is chrome trim on the tail fins. The chrome strip along the sides and over the rear wheel wells appeared on 112s only.
The tail lights and, of course, headlights, are 110. The black painted wood on the dash is also 110. 111/112s came with varnished wood veneer dash panels. The knobs on the dash were used in all 66' and earlier cars.
From what I can see of the engine compartment, my guess would be that this car is a '66 230 with a four cylinder engine dropped in. The 200 badge on the trunk was changed to match the new engine.
baltobenz is offline
    W110 and W111 GrimJettaGLI Vintage Mercedes-Benz 21 11-20-2014 09:45 AM
    Windshield for W110 and W111 kavadarci Vintage Mercedes-Benz 2 09-06-2008 07:10 AM
    W110 BILLSONG Vintage Mercedes-Benz 14 08-28-2008 03:19 PM
    WTB: W110 Parts baco99 For Sale/Wanted/Trade/Giveaway 2 07-02-2008 02:25 PM
    Any W110 200D owners? baco99 Vintage Mercedes-Benz 5 05-26-2008 05:24 AM
