w108 Door Problem - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 06-26-2009, 12:21 PM Thread Starter
Date registered: Nov 2008
Vehicle: 1971 280SE
w108 Door Problem
Hello. I have a '71 280SE w108. It's in pretty good condition overall, but I do have one small problem with it: the driver's door does not stay open, like the rest of the doors do. When it opens, it opens smoothly, without the catch-stop-things that keep it open at certain points. If you leave the door open, it closes itself on its own.
While this might not really seem like that much of a problem, it sort of is, because, if, for instance, you open the door, put your leg out, then reach over to the passenger's seat to grab something, the door comes back and whacks your shins! Not fun.
So, I'm wondering, before I do anything, which part's breakage would cause this? And, would it be very easy to fix, or would it be too much trouble to fix it? I apologize for my limited vocabulary; I really don't know what some of these things are called
Thanks,
Daniel
correlation is offline
post #2 of 9 (permalink) Old 06-26-2009, 12:45 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
It is the door-stop. A common replacement part, and easily done. Pretty cheap as well. A very handy safety item, to be sure. A junkyard item, and about 30 minutes of work.
renaissance_warrior is offline
post #3 of 9 (permalink) Old 06-26-2009, 01:26 PM Thread Starter
Vehicle: 1971 280SE
Okay, that's good, I just wanted to make sure it wouldn't be too difficult or something. Thanks!
post #4 of 9 (permalink) Old 06-26-2009, 01:49 PM
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1973 W115 200 /8
It's easy as eating..
-Remove the door panel.
-Loosen the locking pin on the A-pillar.
-Remove the 2 10mm bolts on the front of the door.
-Remove the litte 10mm nut on the doors inside.
-Take the door-stopper out through the lower hole on the inside of the door.
1991 W140 400 SE - SOLD !!
1973 W115 200 -For sale as project.
Eirik 400 SE is offline
post #5 of 9 (permalink) Old 06-26-2009, 04:24 PM
Be aware as well, you will need something wide and thin to remove the door panels. The plastic clips are prone to breakage. They are available, but why replace if a gentle but firm lift can do the job? A wide paint scraper is best, wider the better.
post #6 of 9 (permalink) Old 06-29-2009, 01:34 PM
Peoria Benz's Avatar
Date registered: Jul 2006
And while you have the door panel off, don't forget to look for any loose pices in the bottom of the door. Often when the door check breaks, part of it end up in the bottom of the door and will rattle from time to time, especially when closing the door.
Peoria Benz is offline
post #7 of 9 (permalink) Old 06-29-2009, 02:01 PM
Date registered: Apr 2008
Quoted: 2 Post(s)
I just replaced both fronts on my W114. I wouldn't go with junkyard ones though. You may end up with ones not much better than what you have. They don't cost that much and are readily available.
mbbuff is offline
post #8 of 9 (permalink) Old 06-30-2009, 12:51 AM
hehe... Here in Norway they cost 100USD per stück..
post #9 of 9 (permalink) Old 07-01-2009, 07:42 PM Thread Starter
Vehicle: 1971 280SE
Okay, thanks! I'll be fixing this shortly.
    W108 - idle/warm start problem Oskar Vintage Mercedes-Benz 12 03-31-2014 09:09 AM
    Idle problem for W108 280SEL (3.5) from 1971....Please help ESOOO Vintage Mercedes-Benz 3 03-30-2008 01:07 PM
    New W108 Owner...Source for W108 Door and Window Seals? LaterApex Vintage Mercedes-Benz 5 03-24-2008 12:51 PM
    WTB :::: W108, 280SEL Door Panels ESOOO For Sale/Wanted/Trade/Giveaway 1 08-21-2007 06:25 AM
    1972 W108 280SE 3.5 Distributor setting problem Guest (MBNZ) General Mercedes-Benz 2 02-15-2001 03:26 PM
