Connection problem of w109 6.3 tachometer in w108 280SE 4.5 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-25-2009, 03:11 PM Thread Starter
Date registered: Jun 2009
Vehicle: 280SE 3.5
Hi everybody,
I just registered to this forum in order to find out solution and share problems of my classic mercedes.Recently I'm dealing with placing vintage VDO tachometer which was used in 300SEL 6.3 to my 1972 280SE 4.5 with electronic ignition.
Few months ago,I bought 6.3 tachometer and last week placed to my car by taking out clock from cluster housing.I connected 12V Power voltage and ground connections.But I have problems with pulse connection.I connected pulse to a cable which is green with yellow lines come from electronic box to terminal.However, on idle it works normal but during accelaration after 2000 rpm it falls down to zero(like it does not work) then when I pull off pedal it jumps again and shows.
According to my opinion as 300SEL 6.3 has standard ignition, pulse is directly got from (-) pole of coil, when I connected to my transistorized ignition due to pulse differences tacho does not read.
Please help for instruction to connect this tachometer to transistorized ignition?Because I saw picture that 6.3 tacho was on 300SEL 3.5 which is also electronic ignition.
Regards,
Kutluhan
Jazzenco is offline
post #2 of 2 (permalink) Old 09-24-2009, 12:13 PM
Peoria Benz's Avatar
Date registered: Jul 2006
I came across a 6.3 tach and tested it and found I was getting too high of a reading at idle and the needle would flutter from 0 to its limit when the revs increased. Anyone know anything about all of this?
Peoria Benz is offline
W108 / W109 Bumper For Sale alabbasi Vintage Mercedes-Benz 0 05-21-2009 09:53 AM
WTB: Wheels from W108, W109 or W113 mangrum For Sale/Wanted/Trade/Giveaway 4 05-21-2009 05:12 AM
I'm in love with the w108/w109 janos_z W126 S,SE,SEC,SEL,SD,SDL Class 12 11-21-2008 09:00 AM
W108 / W109 Aircon sklas Vintage Mercedes-Benz 11 03-07-2008 09:12 PM
1972 W108 280SE 3.5 Distributor setting problem Guest (MBNZ) General Mercedes-Benz 2 02-15-2001 03:26 PM
