MB 250 SE - 66 idle/start problems - Mercedes-Benz Forum
post #1 of 23 (permalink) Old 06-25-2009, 12:12 PM Thread Starter
p74
Date registered: Jun 2009
Vehicle: MERCEDES 250 SE -66
Exclamation MB 250 SE - 66 idle/start problems
I just bought a nice MB 250 SE -66 to have as summer recreation car but it turns out to have problems to start and also runs very bad/not at all when its warm??
Starting when cold is no problem and the car runs proper but as soon as its gets warm the it´s almost impossible to start?
Has anyone had a similar problem?
Would be very grateful for hints...
p74 is offline
post #2 of 23 (permalink) Old 06-26-2009, 01:27 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
It would appear that you have a bad warm-up regulator. On the top of your injection pump is a tower with two water hoses coming out of it. Remove the two screws securing the tower, and remove the brass cylinder with the pin on the end. This is the thermostat for the injection pump that progressively leans out the mixture as the engine is running. It is a simple maintainence item. Make sure to replace the gasket as well. Good luck and welcome aboard!
Mark in Spokane, WA, USA
renaissance_warrior is offline
post #3 of 23 (permalink) Old 06-27-2009, 12:47 PM Thread Starter
p74
Thanks for the tip! I will replace the thermostat for the injection pump and see what will happen to the idle when the motor gets warm.
p74 is offline
post #4 of 23 (permalink) Old 06-27-2009, 01:45 PM
Very welcome. A common replacement part, just like your thermostat. BTW, which I would replace as well. They both use the same wax and it is probably ready to bail as well.
post #5 of 23 (permalink) Old 06-28-2009, 05:09 PM
Post Thermostat could be jammed
After driving for a while; see if the bottom of the raditor is hot, if hot then the thermostat OK; if not then take thermo out and test it by dipping in boiling water. If the lid moves up and down then thermostat OK if not you may have found the problem.
Let us know how it goes.
C180MB is offline
post #6 of 23 (permalink) Old 06-30-2009, 12:49 PM Thread Starter
p74
I dismantled the thermostat house on the injection pump and it does not look very healthy..
I will try to find a replacement housing.
Is the injection pump/thermostat housing the same as used in the later 280SE >72 since they seem to more common around here?
I attached some pictures of the thermostat housing. I guess there should be a rubber seal instaed of the grey stuff they used to fix the thermostat?
ID:	246703   Click image for larger version
p74 is offline
post #7 of 23 (permalink) Old 06-30-2009, 01:07 PM
You are correct. It is a rubber o-ring IIRC. Those are an easy find at a boneyard, you definitely need a new one. Yes, they are all the same on the 6-element pumps
post #8 of 23 (permalink) Old 07-01-2009, 04:50 PM
Unhappy You need a new one
yup, tht thing is unrepairable. Sure you must have been leaking water - did you notice it?
C180MB is offline
post #9 of 23 (permalink) Old 07-02-2009, 04:20 AM Thread Starter
p74
No that´s the funny thing that it did not leak any water!!
I have had the car in the garage and could not spot any water on the floor but i guess it was just a matter of time before that would happen.
I am now hunting for som spare thermostathousing.
p74 is offline
post #10 of 23 (permalink) Old 07-03-2009, 11:41 PM
Update?
    Hard start (esp. when Cold), low idle-- Idle Control Valve? Erwin8r W124 E,CE,D,TD Class 17 08-31-2012 10:22 AM
    Low idle, rough idle, stalling, hot and cold start solved: E320/300 rvenerac W124 E,CE,D,TD Class 10 03-23-2010 12:28 AM
    350SDL idle problems at start Ekdal W126 S,SE,SEC,SEL,SD,SDL Class 2 06-26-2009 08:32 PM
    two problems : humming at start up / rough idle until warm 90 w126 420 se W126 S,SE,SEC,SEL,SD,SDL Class 11 10-02-2007 07:50 PM
    My 250 wont idle lemmyb W123 E,CE,D,CD,TD,TE Class 1 10-13-2004 07:22 AM
