MB 250 SE - 66 idle/start problems - Page 3 - Mercedes-Benz Forum
post #21 of 23 (permalink) Old 08-26-2009, 11:38 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
Air-flow mass meters were not on a 1966 Benz, more like 76. It is an early K-jectronic, obviously.
C180MB, please present your facts more accurately as we can be of more accurate assistance.
renaissance_warrior is offline
post #22 of 23 (permalink) Old 08-31-2009, 01:45 AM Thread Starter
Date registered: Jun 2009
Vehicle: MERCEDES 250 SE -66
The little air cleaner? is that the one on the injection pump you are reffering to?
I am not so familiar with this system yet and i haven´t found a service manual yet.
Actually i don´t know where the cold start valve is either, i have searched in the owners manual but haven´t found much.
p74 is offline
post #23 of 23 (permalink) Old 09-10-2009, 06:33 AM
Date registered: Jan 2007
Quoted: 82 Post(s)
Yes, on the pump, actually on the warm-running device. It screws in and there may be a nut that tightens against the housing to hold it.
The cold start valve is on the right side near the fender. It has a fuel line (pressurized) and a wire for the solenoid.
As a general guide, the Haynes manual, #63020 (230, 250, 280) works pretty well.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
    Hard start (esp. when Cold), low idle-- Idle Control Valve? Erwin8r W124 E,CE,D,TD Class 17 08-31-2012 09:22 AM
    Low idle, rough idle, stalling, hot and cold start solved: E320/300 rvenerac W124 E,CE,D,TD Class 10 03-22-2010 11:28 PM
    350SDL idle problems at start Ekdal W126 S,SE,SEC,SEL,SD,SDL Class 2 06-26-2009 07:32 PM
    two problems : humming at start up / rough idle until warm 90 w126 420 se W126 S,SE,SEC,SEL,SD,SDL Class 11 10-02-2007 06:50 PM
    My 250 wont idle lemmyb W123 E,CE,D,CD,TD,TE Class 1 10-13-2004 06:22 AM
