MB 250 SE - 66 idle/start problems - Page 2 - Mercedes-Benz Forum
post #11 of 23 (permalink) Old 07-04-2009, 12:14 PM Thread Starter
p74
Date registered: Jun 2009
Vehicle: MERCEDES 250 SE -66
I am still looking for the thermostat housing and i hopefully will get an answer from a guy next week...lets really hope..
p74 is offline
post #12 of 23 (permalink) Old 08-23-2009, 08:20 AM Thread Starter
p74
I finally got hold on a better used thermostat housing after a long search...I mounted it and it seems to work except that the warmstart problem persists...
I don´t actually know what to do next?
p74 is offline
post #13 of 23 (permalink) Old 08-23-2009, 09:25 AM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
Did you replace the thermostat?
renaissance_warrior is offline
post #14 of 23 (permalink) Old 08-23-2009, 10:03 AM Thread Starter
p74
Carbs adjusted? The engine has an injection unit.
Yes i replaced the thermostat but it seems that something else is not right.
p74 is offline
post #15 of 23 (permalink) Old 08-23-2009, 01:12 PM
Sorry, I didnt remember. See if your cold start valve is leaking. Take it out when it is warm, and plug the opening wit duct tape and re-start the engine. If it leaks, you need another one.
Other ideas; valves tight, injection pump idle mixture adjustment needs leaned out or enrichened, (wheel on back of it) clockwise is lean, counter is rich, only do 1 or two clicks at a time. You really need to buy a shop manual.
post #16 of 23 (permalink) Old 08-24-2009, 12:01 AM
wbain's Avatar
Date registered: Dec 2003
Well, with the look of that housing you may have had coolant leaking into the guts of the injection pump. There is a plunger under the long pin that cuts off additional air during warmup. The plunger should move freely and if stuck, the housing needs to be removed, disassembled, cleaned and possibly honed.
wbain is offline
post #17 of 23 (permalink) Old 08-24-2009, 09:54 AM
With all due respect, the pump has no cold-start air control function. The thermostat is pretty much self-sealin, and coolant in the pump is a remote possibility.
I would run a can of 44k in a tank of fuel and clean all the varnish out of the system before doin anythin else. Varnish can wreak havoc on mechanical injection systems.
post #18 of 23 (permalink) Old 08-25-2009, 12:36 AM
I sorted my cold start problem by repacing the air- flow mass meter. It waas tkaing the wrong reading and passing it on to ICU - replaced it with a cheaper Chinese make, a 1/5th of the price with 12 months warranty - lets see how it goes.
C180MB is offline
post #19 of 23 (permalink) Old 08-25-2009, 01:43 PM
Your car is much newer than a 66 then.
post #20 of 23 (permalink) Old 08-25-2009, 06:26 PM
Date registered: Jan 2007
Quoted: 85 Post(s)
You can put the warm-up regulator device issue to rest very easily. Remove the little air cleaner. Start the engine cold. Put your finger over the hole, and you should feel suction from the extra air being pulled in to raise the idle. This will diminish as the engine warms. When the engine is warmed up, there should be no suction.
If there is suction when warm, then that is a problem. The extra air is causing a lean condition.
Please do this check and report, as the next steps are more complicated.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
    Hard start (esp. when Cold), low idle-- Idle Control Valve? Erwin8r W124 E,CE,D,TD Class 17 08-31-2012 10:22 AM
    Low idle, rough idle, stalling, hot and cold start solved: E320/300 rvenerac W124 E,CE,D,TD Class 10 03-23-2010 12:28 AM
    350SDL idle problems at start Ekdal W126 S,SE,SEC,SEL,SD,SDL Class 2 06-26-2009 08:32 PM
    two problems : humming at start up / rough idle until warm 90 w126 420 se W126 S,SE,SEC,SEL,SD,SDL Class 11 10-02-2007 07:50 PM
    My 250 wont idle lemmyb W123 E,CE,D,CD,TD,TE Class 1 10-13-2004 07:22 AM
