Fuel in crank case of 73 450 slc - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-25-2009, 04:50 AM Thread Starter
Date registered: Jun 2009
I recently inherited a 1973 450SLC from my Brother-in-Law. It had not been started in a year.
It will not start. It is over fueling badly and fills the crank with fuel.
Help!
GrandBenzer is offline
post #2 of 2 (permalink) Old 06-25-2009, 10:21 AM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
Check the fuel pressure regulator.It is the diaphragm on the fuel rail with a vacuum connection on the back. Look at the vacuum line first, it may be rotted or leaking. The next thing I would do is to remove the injectors, all of them and see if any of them are stuck and not closing. Crank it over with the injectors removed, and lay them on a towel over the engine. Make sure to buy new seals for the bottoms before you re-install them. Look for ones that are continuously spraying. Another would be the cold start injector.
renaissance_warrior is offline
'73 450 SLC help. Cabot R/C107 SL/SLC Class 8 05-10-2009 08:15 AM
77 450 slc/ 79 500 slc dtresserd R/C107 SL/SLC Class 2 05-13-2008 01:40 PM
450 SLC tobybul R/C107 SL/SLC Class 11 07-11-2007 05:50 PM
In case your ML randomly does not crank.. AC_ML W163 M-Class 4 05-14-2007 08:58 PM
'72 450 SLC Guest (MBNZ) R/C107 SL/SLC Class 0 06-25-2002 05:38 PM
