1976 450 sel cranks but won't start... - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-22-2009, 07:49 AM Thread Starter
Date registered: Jun 2009
Have a 76' 450sel. cranks but doesn't turn over. I shoot some carb cleaner down the intake and then it turns over then dies once all the carb cleaner is burned through. Car sat for a few years. When it was last started it started right up.
fuel pump gone bad? i can't hear the pump when cranking the engine.
any other ideas?
please help
JanR is offline
post #2 of 4 (permalink) Old 06-24-2009, 07:43 AM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
Well, do the dynamic duo, spark and fuel. Take out a plug, and see if it sparks. Next, get a rag and remove the cold start injector line at the injector. Crank, and look for fuel. If not, chane out relay, if no fuel still, chan out pump.
You can also just do a voltage test at the fuel pump terminals, that is easiest. If power is to it when cranking , bad pump.
renaissance_warrior is offline
post #3 of 4 (permalink) Old 06-24-2009, 06:46 PM
Date registered: Sep 2008
it could be bad gas, although it should still start, and just not run great.
I've been told that the lifespan of gas is only supposed to be 3 to 4 months, probably 6 at best. At the same time though my merc had been sitting for 2 years and the gas was still ok, not great though, but enough to have it running.
ebouwman is offline
post #4 of 4 (permalink) Old 06-30-2009, 09:48 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
Open up the fusebox and replace EVERY ceramic fuse with a new one. See if that improves your starting.
Ed Mclass is offline
    1976 450 sl exhaust homecooking R/C107 SL/SLC Class 4 04-06-2009 11:45 AM
    1976 450 SL boxofcheez W116 S, SE, SEL, SD Class 2 04-06-2009 08:55 AM
    No start-Hard start, multiple cranks, Help??? gquarrick W210 E-Class 13 11-24-2008 03:16 PM
    1976 450 sl won't run...... squirrel_master R/C107 SL/SLC Class 2 09-24-2006 09:32 PM
    I just inherited a Mint condition 1976 450 SEL !!! Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 3 06-24-2002 05:18 PM
