Hirschmann power antenna - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-20-2009, 04:17 PM Thread Starter
Date registered: Apr 2009
Vehicle: 2007 ML350 4Matic, 2002 E320 4Matic, 1975 350SE, 1975 230.4
Smile Hirschmann power antenna
I just got a hirschmann power antenna for my W115. Its the old 3 pin type. I tested it and antenna goes up fine. Now I can't make it go down.
Red on positive and Brown wire on negative. Put the white wire (Signal) to positive and antenna went up. Did the same again but won't go down. Anyone knows how to make it go back down?
davin517 is offline
post #2 of 3 (permalink) Old 06-22-2009, 12:06 PM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
Give TOM a call at 201-773-0976 or index. He can offer a solution.
Ed Mclass is offline
post #3 of 3 (permalink) Old 06-23-2009, 03:18 AM
Date registered: Jun 2009
Disconnect your antenna switch from the little electrical holder. Find the hot going into the switch. The normal position going up of the switch and test it for continuity using a multimeter. Now the other side going down. You should have the same for the other side.
The antenna has a motor that is a DC motor. DC motors can be reversed and this is why they go down. Find a comparable switch and replace it for a check and try again. You might see the antenna go down.
I have a knack for this stuff.
GenBiltstein is offline
    Broken 300TD Hirschmann Antenna? kwake W124 E,CE,D,TD Class 0 04-19-2009 07:15 AM
    Hirschmann Antenna connection poschet Audio & Telematics Forum 0 05-21-2008 09:32 PM
    FS: Hirschmann Power Antenna smemolo For Sale/Wanted/Trade/Giveaway 1 09-17-2007 04:07 PM
    1997 sl500 Hirschmann power antenna JohnDB General Mercedes-Benz 2 06-09-2006 11:03 AM
    Replacement Hirschmann antenna mast lechonlubber Audio & Telematics Forum 1 09-10-2003 11:06 AM
