67 250se/c alternator wiring Question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-16-2009, 12:35 AM Thread Starter
ChopTop250SE's Avatar
Vehicle: 1967 250SE RHD, 1969 300SE L, 1989 560SEC with AMG upgrades, 1998 s600 coupe
Send a message via MSN to ChopTop250SE
Hey guys,
Is anyone familiar with the alternator wiring on a 67 250se coupe? I have the alternator which has the triangular shaped plug (with round/cylindrical connectors --not the 3 flat connectors) .... I also have an external voltage regulator.... the car was taken apart for refurbishing/customiziation and is now being put back together....besides the 3 wires that connect with that plug (DF, D+, D-) are there any other wires that supposed to go into the alternator? If so, where are they supposed to go from the alternator, where do they lead exactly and how? I am asking this 'cause I noticed today there is a terminal with a nut that looks like it should have a wire going to it from????
Cheers
ChopTop250SE is offline
post #2 of 3 (permalink) Old 06-18-2009, 04:18 PM
Date registered: Jan 2007
Quoted: 85 Post(s)
I believe that's where the large wire that connects to the battery via a connection at the starter goes. There is a smaller terminal that is sometimes used for a ground strap.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #3 of 3 (permalink) Old 06-20-2009, 02:39 AM Thread Starter
Thank you...That makes sence
    Need wiring harness to the starter, alternator part # lesko W140 S-Class 16 08-31-2016 05:15 PM
    115 Amp Alternator Upgrade Wiring Help christophesteele W123 E,CE,D,CD,TD,TE Class 1 07-27-2008 11:19 AM
    Alternator Wiring A5RGS W124 E,CE,D,TD Class 6 03-05-2008 08:00 PM
    406/416 Alternator Wiring: Need Help!! mserpe Unimog 2 09-27-2006 07:13 PM
    Alternator question.. Jenz_benz W126 S,SE,SEC,SEL,SD,SDL Class 0 12-21-2005 10:30 PM
