1974 240D Alignment specs - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-28-2009, 06:57 AM Thread Starter
Date registered: Apr 2009
Took her to a shop to get the front end aligned and they can't find specs anywhere. They are not in my service manual. Thanks for any assistance.
24td is offline
post #2 of 4 (permalink) Old 05-28-2009, 04:59 PM
mbkomfort's Avatar
Date registered: Jan 2008
Vehicle: -88 250D, -93 280TE-24 Sportline and -00 E270T CDI
Ask at the MB dealer? could you find R107 specs, they have allmost the same suspension..?
mbkomfort is offline
post #3 of 4 (permalink) Old 06-02-2009, 07:57 PM
Date registered: Mar 2009
Here's what I got for the front
Camber: 0 degree -20'.
Caster: {mech steer. 2 degree 40'+-20'} {Power steer. 3 degree 40' +- 20'}
VagusX is offline
post #4 of 4 (permalink) Old 06-03-2009, 05:04 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
If the alignment shop doesn't have the specs, doesn't use a spreader bar and doesn't lock the steering box per the service manual directions, then don't expect a perfect alignment. Might be good enough for government work if that's all you want, but your best bet is likely the dealer. Get it done once and right the first time.
sokoloff is offline
    Alignment Specs Indiana Drew G-Class 12 05-11-2012 01:54 PM
    Alignment specs. ChuangTzu W123 E,CE,D,CD,TD,TE Class 8 11-17-2009 08:55 AM
    alignment specs sixbangr W210 E-Class 1 08-10-2008 04:25 PM
    Alignment Specs Kingorcus W126 S,SE,SEC,SEL,SD,SDL Class 3 05-29-2007 07:43 AM
    Alignment Specs for a 55? slk55er R171 SLK-Class 2 07-27-2006 01:47 PM
