no dash lights - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-25-2009, 06:43 PM Thread Starter
Date registered: May 2009
Vehicle: 1974-450SEL-4.5L
Red face no dash lights
hi everyone, hope you all are well,my dad passed away last march,and he had left me his 1974 450 SEL, in very nice shape,i just tuned it up today and tried to fix the dash lights, but no luck, fuses are good, after that i am clueless any help would be nice,
bentheplumber is offline
post #2 of 7 (permalink) Old 05-26-2009, 07:14 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
A search will bring up lots of info and step by steps. You likely have a bad rheostat. It is located behind the dimmer control on your dash. You do know that you have a dimmer control right? It is the little knob that resets your trip meter. Turns it to the right to brighten the dash lights. Its not all that bright even at the max. Maybe that's all you need? Some have had luck by just twisting it back and forth about a hundred times.
Sorry about your dad.
Len
sokoloff is offline
post #3 of 7 (permalink) Old 05-26-2009, 07:20 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
Even if the fuses "look" good they are subject to failure because of oxidation. It would be a good idea to replace all of them with new fuses of the correct size. You may be surprised what a difference it makes!
Ed Mclass is offline
post #4 of 7 (permalink) Old 05-26-2009, 08:20 AM
robgigliotti's Avatar
Date registered: Feb 2009
I took the cluster out of my 69 and cleaned every contact, taking much care in taking the rheostat apart there a couple of small springs in there. Changed every light bulb and put it all back together and it worked. I was shocked!! Just take your time...
______________________________
1984 300sd -
1969 220d -
1997 Chevy Suburban -
robgigliotti is offline
post #5 of 7 (permalink) Old 05-26-2009, 06:55 PM Thread Starter
thanks for all yor great advice and your help will try all of them ,regards ben
post #6 of 7 (permalink) Old 05-27-2009, 07:47 PM
Date registered: Sep 2008
Can you just bypass the rheostat so that it just stays on max brightness?
ebouwman is offline
post #7 of 7 (permalink) Old 05-28-2009, 07:23 PM
Quoted: 30 Post(s)
Yep - that's what a lot of us have done. Just jumper a wire between the two terminals on the rheostat.
Len
sokoloff is offline
    Dash Lights / Console Lights ClearDark W123 E,CE,D,CD,TD,TE Class 18 04-10-2012 04:14 AM
    dash lights won't turn off (idiot lights) imosh R129 SL-Class 2 01-10-2009 06:41 AM
    dash lights keep going out mikebrou R129 SL-Class 0 03-08-2007 10:35 PM
    Dash Lights grandshervee W163 M-Class 1 03-22-2003 04:47 PM
    no dash, lights,radio, console lights(1984 500SEL) 4benzes W126 S,SE,SEC,SEL,SD,SDL Class 2 12-01-2002 04:59 PM
