71 280se 3.5 idle surges when cold and slight chatter in motor - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-25-2009, 12:06 PM Thread Starter
Date registered: May 2009
Vehicle: 1971 280se 3.5,1983 240d
Post 71 280se 3.5 idle surges when cold and slight chatter in motor
my 1971 280se 3.5 ia actually a gorgous car and gets tons of looks but when initial startup i get idle surges until it warms up.. Could it be a cold start valve? Where is it located? The book I have has the six cylider and not the 8 so I have no reference.. Also there is slight chatter I belive in the top end.. an the valves be adjusted with the overhead cams. I know my diesel can be.. If so where can I get spec for the valve adjustment.. Thanks Mike
boathousemike is offline
post #2 of 5 (permalink) Old 05-27-2009, 06:03 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
Contact the Classic Center for information and a correct owners manual. thomas.hanson@mbusa.com or 1-949-598-4842.
Ed Mclass is offline
post #3 of 5 (permalink) Old 05-27-2009, 07:52 AM
Yes adjust the valves, (special tool needed) .006 in .008 exh
Check timing chain slack.
Do a full electrical tune-up, timing on spec,
Then we can address the cold idle surge,
I have had the same issue, once.
Brian O
bostosh is offline
post #4 of 5 (permalink) Old 05-28-2009, 05:50 AM
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 11 Post(s)
First check the vacuum line from the ignition to intake butterfly. A vacuum leak there may generate too much advance at idle and engine surging. Then check that your vacuum advance works properly (you should see the flange inside the distributor moving when you suck through the vacuum line). Then check points and advance setting. Advance at idle should be between 0° at 4° retarded, ie after the 0, with vacuum line connected). Once ignition is all correct you can look at injection components. I noted that warmer weather requires richer idle (too lean also create engine surging). Which is strange because cold air is denser hence with more Oxygen for a given volume. Increase idle richness by turning the knob on the injection calculator by a few clicks. Count them as to be able to come back where it was in case the problem is elsewhere.
GGR is offline
post #5 of 5 (permalink) Old 05-29-2009, 11:20 AM
Peoria Benz's Avatar
Date registered: Jul 2006
Cold surging is often the auxiliary air valve going bad. But the other suggestions are valid as well. Good luck!
Peoria Benz is offline
    Valve adjustment, now slight chatter..... bpjenks W123 E,CE,D,CD,TD,TE Class 7 01-29-2009 07:08 AM
    Hesitates then Surges on accel when cold CambridgeMA W210 E-Class 5 12-29-2007 09:05 AM
    Wanted to thank the board on the blower motor squirrel cage chatter fabbrisd W140 S-Class 0 04-14-2006 08:55 AM
    throttle surges when car is cold.... baudenfj W124 E,CE,D,TD Class 0 12-06-2005 09:18 PM
    surges in idle Guest (MBNZ) R/C107 SL/SLC Class 1 06-27-2002 07:35 AM
