engine overheat sensor test - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-25-2009, 06:39 AM Thread Starter
Date registered: Jan 2008
Vehicle: 1971 280se conv. European spec 6 cylinder imported here years ago and converted to a V8
Last year the engine became very hot at idle in a traffic jam on my 71 280se 3.5 and the radiator fan did not come on as it should.
I tested the fan and it works perfectly and now want to check the engine temperature sensor works. What is the best way to do this?
Thanks
Adrian
Montclair Benz is offline
post #2 of 3 (permalink) Old 05-25-2009, 07:31 AM
with an ohm meter, check cold resistance then check in boiling water,
Change of resistance indicated functioning.
absolute values indicate how well it works.
It is an open or closed switch.
Brian O
bostosh is offline
post #3 of 3 (permalink) Old 05-25-2009, 07:50 AM Thread Starter
Thanks.
Overheat Engine !!!!! HELP Filip1981pl R129 SL-Class 0 05-12-2009 01:36 PM
Crank sensor test... max47 W201 190-Class 87 02-16-2009 06:27 PM
check engine Cam sensor,knock sensor 1 and 5 cylinder misfire? kuku369 W210 E-Class 8 11-16-2008 06:25 PM
O2 sensor test connector cjscopp W126 S,SE,SEC,SEL,SD,SDL Class 0 03-21-2006 07:42 AM
95 E200. Oil sender sensor location, brake pad sensor location, engine code? cubicincubi W124 E,CE,D,TD Class 2 01-04-2006 08:07 AM
