weather stripping questions - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-21-2009, 03:26 PM Thread Starter
betoface326's Avatar
Date registered: Apr 2009
Vehicle: 1972 Mercedes Benz 280SE 4.5
I started adding new door weatherstripping to my 280SE and realize that there are screw holes in the rubber. Is there a proper screw size and where can I find these? Also, I noticed in a diagram the Retaining rail which seems like it might steady the rubber along the door. My car doesn't seem to have this since the weather stripping was missing - can I proceed and add these in later? I'd like to settle these questions before I use the adhesive to seal the rubber to the door.
Also, it looks like the door checks need to be removed - is there a rundown on this somewhere?
betoface326 is offline
post #2 of 3 (permalink) Old 05-23-2009, 04:59 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
You might give Tom Hanson a call at the Classic Center down in Irvine, CA. 1-866-622-5277. You should not to remove the door checks to do this.
Ed Mclass is offline
post #3 of 3 (permalink) Old 05-23-2009, 06:07 AM
Date registered: Nov 2003
You should be able to remove the door check strap's pin easily. I'm not aware of any screws nor am I aware that adhesive is needed for the front doors. Make sure you use factory parts for a proper fit and keep us posted on your progress.
E430_4Matic is offline
    Weather Stripping lfedje R/C107 SL/SLC Class 10 03-27-2008 12:18 PM
    Weather Stripping TAS62 R/C107 SL/SLC Class 2 07-09-2007 06:56 AM
    Weather stripping Benzoid123 W123 E,CE,D,CD,TD,TE Class 11 02-07-2007 07:23 PM
    weather stripping black cloud W123 E,CE,D,CD,TD,TE Class 4 09-23-2005 07:29 AM
    Weather Stripping Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 1 05-01-2004 01:11 AM
