tie rods and drag link off - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-20-2009, 11:47 AM Thread Starter
Date registered: Aug 2008
I am replacing the tie rods and drag link on the front of my 1972 280 SEL 4.5L The problem is that I can get the old bits off. Not even the pickle fork works. Any ideas? Will heating help or cause more problems?
robert!@# is offline
post #2 of 3 (permalink) Old 05-20-2009, 07:21 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Don't use heat on suspension parts. I got mine off using a ball joint sepaarator to apply force to the tie rod end stud and then tapping on the drag link when the tapered stud goes through.
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #3 of 3 (permalink) Old 05-21-2009, 09:18 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Many of the McParts stores loan you tools for such jobs.
sokoloff is offline
    Centerlink / Inner Tie Rod / Drag Link....HELP! deyainrdy4ds C208/A208 CLK-Class 32 03-11-2009 09:37 AM
    tie rod and drag link replacement p100 W126 S,SE,SEC,SEL,SD,SDL Class 1 05-03-2008 09:29 PM
    Panhard Bar, Drag Links and Tie Rods NM_Mogman Unimog 2 07-27-2007 10:08 PM
    tie rod & drag link ends Kuzuki G-Class 4 05-18-2005 06:06 PM
    tie rod ends and drag link mike G-Class 3 03-25-2003 06:40 PM
