torque arms rubber doughnut - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-20-2009, 11:40 AM Thread Starter
Date registered: Aug 2008
I am replacing the rubber pieces on the suspension of my 1972 280 SEL 4.5L. I cannot get the forward end of the rear torque arms back on. The alignment is nearly impossible to get perfect, and if not perfect the bolt won't line up. Even when spot on the inside hole of the doughnut it too small to fit onto the mount on the body. Any ideas on how to make this fit? Is there any problem with grinding out the inside of the doughnut to make a larger hole?
robert!@# is offline
post #2 of 4 (permalink) Old 05-20-2009, 07:25 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Don't enlarge the hole-it will cause play. You might spray some silicon spray on the bushing to make it go easier-you would be surprized at what a difference it makes. I think that's what I did when I installed my rear axle.
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #3 of 4 (permalink) Old 05-21-2009, 03:52 PM
Tony is correct. It will fit, lube the hole and jack it up and on.
I use a bottle jack on the front end of the arm with the car nearly on the ground. weight of car is on the rear wheels.
Brian O
bostosh is offline
post #4 of 4 (permalink) Old 05-22-2009, 08:42 PM
wbain's Avatar
Date registered: Dec 2003
Make sure the axle tubes are level and use a lubricant on the pins and rubber.
wbain is offline
    Walworth County cop wins doughnut eating world title for third time Jakarta Expat Off-Topic 0 05-02-2009 02:26 AM
    rubber OEM rubber mats Bigburgundy W163 M-Class 5 01-06-2008 04:13 PM
    New lower control arms bushing and control arms still loose sheffmb W140 S-Class 0 11-20-2007 08:24 PM
    416 torque tube rubber sleeve milspecrestro Unimog 3 09-10-2006 12:04 PM
    Rubber bearing of longitudinal arms Saad Ghouth G-Class 2 09-30-2001 02:21 PM
