1987 280GE Ignition switch - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-11-2009, 05:38 AM Thread Starter
Date registered: May 2009
Question 1987 280GE Ignition switch
Hello, recently I received a 1987 280GE. I've had the truck worked on and just replaced the exhaust and it runs great. However, recently I have had a problem with the truck shutting off as if someone was hitting a kill switch. I believe this problem is coming from the ignition coil or ignition switch. Has anyone ever had this problem before and does anyone know the best place to get these parts?
Thanks very much. I appreciate any and all advice!
cdriza is offline
post #2 of 3 (permalink) Old 05-11-2009, 05:46 AM Thread Starter
Also, just to elaborate a little further on the problem, when the car does shut off, if I hold it in the "crank" position or hold the started on, the truck will continue to run. Any ideas?
cdriza is offline
post #3 of 3 (permalink) Old 05-11-2009, 11:53 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
280 GE
Be sure to check the ground strap from the engine to the frame. You could have a bad ground from the engine to the frame. Rust can do this too. For parts you can check with Steve or Sean at Eurotruck Importers, Your source for Mercedes-Benz off-road vehicles and spare parts!. They are located in the U.S.
Ed Mclass is offline
    1987 300TD Ignition Switch Replacement jteleky W124 E,CE,D,TD Class 1 04-28-2009 06:09 PM
    ignition lock cylinder & ignition switch lakeside W164 M-Class 2 07-23-2007 05:55 PM
    1987 280ge body parts forsale keychi G-Class 11 02-04-2007 02:58 PM
    1987 280ge Toronto230GE G-Class 0 06-12-2004 02:51 PM
    1987 280GE on Ebay !! Mark G-Class 2 01-27-2002 04:44 PM
