220se fuel injectors - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-01-2009, 11:55 AM Thread Starter
Date registered: Mar 2009
I'm getting the motor ready to be started and I wanted to test
the fuel injectors to make shure they pop and the correct pressure.
The book I have say they should pop at 13 to 15.5 atu which I believe
mean atmoshere.That would put the pop off pressure at 190 to 230 psi.
Is that right?
Redpawn is offline
post #2 of 5 (permalink) Old 05-01-2009, 09:10 PM
wbain's Avatar
Date registered: Dec 2003
Yes, they are high pressure injectors.
wbain is offline
post #3 of 5 (permalink) Old 05-01-2009, 10:31 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
Just drive it and put a can of K-44 in a full tank. Change plugs and oil afterwards, then tune. Done deal. I am a former old-school MB mechanic from that very time.
Please be aware that I have no relationship whatsover with the following product. It is just what we used, based upon non-compensated results. Old-school reality like Marvel Mystery Oil. It is what it is, and needs no endorsements.
Worry more about the pattern than the pressure. Parasitic spray from deposits is your enemy. You need to get rid of them first, K-44 does that. It is literally pure Techron that Chevron is so orgasmic about, but it has been around for about 30 years. Chevron adds it to their fuel, but in minute doses. Much like white truffles to a Subway sandwich. Infitesmal.
It is normally found at better shops for sale, or Firestone dealers. About $17 a can. MB techs love it, those that know of it at least. It is the anti-gummer and varnish remover from hell in all regards.
We do not and never did use crap additives that do not work. Customers pay enough already for the service, they expect tangible, accellerator pedal proven results, and we are expected to deliver. And that we both did and do.
renaissance_warrior is offline
post #4 of 5 (permalink) Old 05-04-2009, 04:12 AM Thread Starter
I was planing to put some of that in the tank when I get it running.We use it here at work and it does a pretty good job.Thanks for the help.
Redpawn is offline
post #5 of 5 (permalink) Old 05-04-2009, 12:48 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
I used it too, when I first got my 280 years ago. That stuff takes care of all kinds of crud and made a huge difference in performance.
Grubeguy is offline
    1997 S500 No Fuel at Injectors (fuel pumps already replaced) dleroux W140 S-Class 11 03-24-2012 03:46 AM
    Jumped fuel relay gets fuel to injectors!Still not starting! Distributor Plunger? salthepal W124 E,CE,D,TD Class 2 10-08-2008 03:24 PM
    fuel injectors spots350sl R/C107 SL/SLC Class 16 05-05-2008 06:56 PM
    bad fuel? problem with fuel injectors? tmpleton88 W203 C-Class 5 08-08-2007 04:26 PM
    280E: Fuel to Cold Start Injector, but not to main injectors - Fuel Press. Regulator? or other?? GermanCarNut W123 E,CE,D,CD,TD,TE Class 0 01-25-2004 03:12 PM
