1974 240D Help with A/C - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-27-2009, 02:27 PM Thread Starter
Date registered: Apr 2009
Hello,
I am trying to get the A/C to work on this vehicle and am not entirely sure where to start.
Here are the things that I know:
Green light does not come on (I am assuming this indicates that the compressor is engaged/disengaged)
Compressor does not engage
System holds pressure
Blower and Blower switches work
So, what I would like to do FIRST is to get the compressor to engage. So I can get the system converted to R-134a.
I don't have any schematics of this system so I could really use a little guidance.
Thanks,
EODVET
EODVET is offline
post #2 of 3 (permalink) Old 04-30-2009, 11:38 AM Thread Starter
Does no one have ANY information on this system?
I would really like to get the A/C in this car working.
EODVET is offline
post #3 of 3 (permalink) Old 05-02-2009, 06:36 PM
Date registered: Feb 2009
your car has 2 blower motors-one for the heat ,located behind the glovebox,and one under the radio,in the console (the grills on each side are the intakes) There is a change-over switch on the left side of the console, above the accelerator pedal,that is operated by vacuum.There is probably a leak in the system.Turn on the ignition and blower switch,if the heater blower is running,reach up by the pedal and actuate the lever on the change-over switch and hold it.If the heater blower turns off and the console blower comes on (the green light and compressor ,too,if the system has enough refrigerant)then you aren't getting the change-over.If you are careful,you can unplug the switch and jump the wires (I don't remember which-it's been years since I did it)to bypass it.Hope this helps.Be sure you clean all the fuses first-not just check-because a little corrosion will stop it. I think there is a small fuse box (2 fuses)on the firewall for the compressor and fan,check the manual if you have one.hope this helps.
clark 54 is offline
    1974 240D mr alaska For Sale/Wanted/Trade/Giveaway 1 04-19-2009 02:17 PM
    1974 240D 24td Vintage Mercedes-Benz 19 04-13-2009 12:18 PM
    1974 240D value LESTON For Sale/Wanted/Trade/Giveaway 5 01-04-2006 01:31 PM
    1974 240D - Help? rodgersj Vintage Mercedes-Benz 2 11-19-2005 09:42 AM
    1974 240D Diesel...How much? Jamison W123 E,CE,D,CD,TD,TE Class 1 05-04-2004 06:51 PM
