280SE 4.5 engine trouble - Page 2 - Mercedes-Benz Forum
post #11 of 42 (permalink) Old 04-26-2009, 10:07 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Old fuel
Hi Brian,
Didn't know you had old gas in the car.
If you have old fuel you car will run badly if at all even if fuel stabilizer was added. The fuel stabilizer only lasts for a few years. You would be amazed at what some fresh fuel would do.
Tony
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #12 of 42 (permalink) Old 04-27-2009, 12:32 AM Thread Starter
betoface326's Avatar
Date registered: Apr 2009
Vehicle: 1972 Mercedes Benz 280SE 4.5
I made it to the gas station and loaded up on some fresh gas + additive and a few quarts of oil (which was suprising low...). It's driving pretty well, but there is still some occasional backfiring noises coming from the engine (not the exhaust though...). I'm hoping to get the 5 miles or so in the morning to the shop without issue for an oil change and inspection.
Thanks again
-Brian
betoface326 is offline
post #13 of 42 (permalink) Old 04-27-2009, 10:57 AM
Quoted: 8 Post(s)
Brian,
How much old fuel was remaining? If there was much it will still influence how the car runs. You need to get all the old fuel out before you can truly evaluate performance.
Tony
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
3.5 Tony is offline
post #14 of 42 (permalink) Old 04-28-2009, 01:13 PM
hbar's Avatar
Date registered: Feb 2007
Vehicle: '74 & '78 450 SEL
Quoted: 703 Post(s)
Originally Posted by betoface326 View Post
Also, I just checked and there is some whitish smoke coming from the exhaust. Not sure what this means... is it safe to drive <5 miles or should i tow it to a shop?
Thanks!
-Brian
Low power + misfiring + white smoke in exhaust = water in combustion chamber
This is usually due to a blown head gasket although it's possible the water is contamination from the car sitting so long.
hbar is offline
post #15 of 42 (permalink) Old 04-28-2009, 02:05 PM Thread Starter
I drove the car around yesterday after taking it in for an oil change/inspection at a MB service location here. I was able to drive around for an hour with the engine never heating up passed 150... There were a few items they mentioned after the inspection (no A/C belt, front end overhaul, rear brake drag, etc.) but nothing that they deemed an emergency. My concern is that there is something going on with the transmission, but I plan to take it in to a local shop (benz friendz) and have them take a look.
I do have a couple of questions:
- Is there a good way to determine if the water is there from sitting, as opposed to a blown head gasket? If so, is there a good way to drain/remove the water?
- What should I tell/ask the mechanic so I don't a) look like a complete idiot, and b) get an overwhelming list of things that are "wrong"?
- What's the best way to determine if I shouldn't be driving it as is?
Thanks again,
Brian
post #16 of 42 (permalink) Old 04-29-2009, 08:37 AM
This car will test you persistence and commitment.
Temperature too low, needs thermostat replaced.
Loose front end, first replace tie rods, drag link, repack and adjust wheel bearings .
Full lubrication service, engine, trans, rear axle.
Grease gun all fittings. front to rear.
Adjust valve clearance, new valve cover gaskets and bolt seals.
Compression and cylinder leak-down test.
Routine items, motor mounts, sub-frame mounts,
then do the other routine items like injector seals, fuel line replacements. on, and on, until all old rubber parts replaced. Lots of rubber items.
But this is why these cars are superior for their time.
And still good cars. just need regular maintenance.
By the way, the newest car I have ever owned is a 280SEL 4.5 (and the 300SEL 6.3)
Yes I am living in the past.
There is no reason to own anything different.
Oh, and note this, on one car (280SEL) I bought with complete maintenance records,
The maintenance $$ over time added up to more than the initial cost of the car, Same is true with Boeing 747's and other mechanical things.
Break out the wallet, there is no free transportation, pay the dealer, the mechanic, the parts supplier, or walk.
Once the maintenance level is up the cost of ownership can be as low as $25 /month average (documented results) even with items such as transmission rebuild.
These are the cheapest cars on the road, over the long haul.
Brian O
bostosh is offline
post #17 of 42 (permalink) Old 04-30-2009, 11:19 AM
4.5_sport's Avatar
Date registered: Apr 2004
Vehicle: 1994 E320T, 1979 VW Rabbit
Send a message via MSN to 4.5_sport
Brian,
I too own an SE 4.5. I live in Tacoma. I had driven mine daily for several years before moving and letting it sit for 2 years....bad choice. I am now in the process of getting it drivable again. Get in touch if you want to talk 4.5's. I'm always around.
Jason
vwwrencher (at) hotmail (dot) com
4.5_sport is offline
post #18 of 42 (permalink) Old 11-14-2009, 08:21 AM
Vehicle: 1972 Mercedes Benz 280 SEL
My 1972 280 SEL 4.5 is running rich. I have replaced the air flow sensor, the water temp sensor and the cold start valve. Even though I have the CD manual, I cannot figure out what the part is next and just to the left of the water temp sensor? It has a brown plastic top with wires coming out of it. The brand appears to be "K" with the number 9656 on it. Can anyone help identify this or give any suggestions as to why the car runs rich? Thanks!
Packard1807 is offline
post #19 of 42 (permalink) Old 11-14-2009, 09:08 AM
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
This may be the thermo switch. It enables the "ECU" to activate the cold start injector when engine is cold. See if your MAP sensor is in good shape. Does it hold vacuum?
GGR is offline
post #20 of 42 (permalink) Old 11-14-2009, 09:11 AM
Thanks. If the door locks work, does that indicate it is holding vacuum?
What is the MAP sensor and where is it located?
Also, could the thermo switch affect the fuel mixture? Where could I buy one? Sorry for all the questions, and thanks for your help.
    280SE Opening the engine zd123 W126 S,SE,SEC,SEL,SD,SDL Class 10 12-03-2008 06:13 AM
    280se 3.5 engine swap abad190 Vintage Mercedes-Benz 8 04-18-2008 09:02 AM
    Engine swap: 280SE with a 300SD engine? stumptown_dan W116 S, SE, SEL, SD Class 3 12-06-2007 10:47 PM
    Starter engine removal on 280SE 4.5 Nick1 Vintage Mercedes-Benz 7 01-24-2007 08:52 PM
    280SE 3,5 Engine Electric Diagram Guest (MBNZ) General Mercedes-Benz 0 03-20-2001 02:36 PM
