Idle problem 250C - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-23-2009, 01:06 PM Thread Starter
Date registered: Apr 2009
Idle problem 250C
Hi, i'm new to this site (and to the world of Mercedes ownership) and joined to see if I could get some mechanical advice.
I have recently purchased a 1970 250C, the car is in decent shape and runs well, or had run well.
Here is the problem, I was driving one day and ran out of gas (dash lights burnt out) figured I had enough gas but guessed wrong. Ever since that happened the car has had problems with idling.
Turn car on and it idles fine
Drive car and it revs and drives fine
Come to a stop and let the car go back to idle, say at a stop light and it cuts out.
Now I hadn't seen this problem before I let it run out of gas so I figure it must be related to that.
Any advice on this would be greatly appriciated.
dmac250 is offline
post #2 of 3 (permalink) Old 04-23-2009, 01:39 PM
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1973 W115 200 /8
Most likely your fuel system is polluted now..
That day you ran out of gas, you drained the tank and got some "bonus" particles along.. They're now stuck in fuel-line, fuel-pump, fuel-filter, and also possibly in the carb itself..
A total clean-up seems to be the most recomended procedure here.
Unclip the fuel-line at the bottom left front side, both lines. (Under the steering-gear)
Drain the system there first.. (Collect the gas, filter it through a coffee-filter, and re-use later)
Unscrew the cap of the fuel-pump.. Clean it properly.
When re-assembling. Put in a fuel-filter on the IN-line..
The carb is a much bigger job to clean.. So I would have waited with that job, to see if those first steps does it for you..
When you test drive, you can try to give it full throttle several times, when the car is HOT of course !! That also can help loosen up the particles that might be lodged in the carb..
If the car now runs fine, then you won't have to dissasemble the carb..
Good luck !
1991 W140 400 SE - SOLD !!
1973 W115 200 -For sale as project.
Eirik 400 SE is offline
post #3 of 3 (permalink) Old 04-24-2009, 04:41 AM Thread Starter
Thanks for the advice, i'll be trying it out soon.
dmac250 is offline
    Testing Idle Valve - High Idle Problem Jonathan Laws W126 S,SE,SEC,SEL,SD,SDL Class 16 08-11-2012 05:55 AM
    1972 250c wont idle and have to keep foot on gas pedal? porshapower Vintage Mercedes-Benz 11 09-25-2008 04:19 AM
    The idle problem won't go away gikn W126 S,SE,SEC,SEL,SD,SDL Class 2 03-30-2007 09:17 PM
    300E Idle problem & A/C vent Problem Guest (MBNZ) W124 E,CE,D,TD Class 6 07-26-2002 10:02 PM
    Need help--idle problem Guest (MBNZ) W202 C-Class 0 10-05-2000 09:07 PM
