1974 240D needs work - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-17-2009, 01:31 PM Thread Starter
Date registered: Apr 2009
My new purchase is in worse shape than I thought.
Full tank leaks fuel(anyone drop their tank?)
All tie rod ends are bad
Idler arm bushings
Window washer not working(bellows pumping, nozzles clean, check valve moving??)
Horns not working (both have one wire off, no power, fuses are good)
Blinker switch broken ( arm won't stay up for right turn, big problem for son with one arm)
Glow plugs only get power while cranking
Vibration while under load
I need a service manual and plenty of parts. Any ideas or suggestions are very much appreciated:
24td is offline
post #2 of 4 (permalink) Old 04-17-2009, 05:29 PM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
Profile
Where are you located?
Ed Mclass is offline
post #3 of 4 (permalink) Old 04-17-2009, 05:52 PM
diametricalbenz's Avatar
Date registered: Oct 2005
Vehicle: '77 6.9, 74 240D, 96 Ram 5.9L Cummins, 02 Civic EX, 10 Mazda 5 Sport
Quoted: 4 Post(s)
Mercedes manual can be had on CD
Also you can peruse the classifieds for parts which can be had for a fraction of the non consumable parts for the car.
www.authohausaz.com has all of the rest of the parts such as the center support bearing. Glow plugs are easy. The washer may need a pump repair on the floor which is removable. The horns are fixable if the wires are just severed. Tie rods and bushings aren't expensive and they last a long time.
1977 - W116 - 6.9
1974 - W115 - 240D /8 - 4(M) OM617.910 + Turbo + 300D FW - Completed 7/8/10
diametricalbenz is offline
post #4 of 4 (permalink) Old 04-17-2009, 07:45 PM Thread Starter
Sturgeon Bay,WI
24td is offline
    1974 240D 24td Vintage Mercedes-Benz 19 04-13-2009 12:18 PM
    1974 240D value LESTON For Sale/Wanted/Trade/Giveaway 5 01-04-2006 01:31 PM
    1974 240D - Help? rodgersj Vintage Mercedes-Benz 2 11-19-2005 09:42 AM
    1974 240D Cheap! Jamison W140 S-Class 0 05-26-2004 02:26 PM
    1974 240D Diesel...How much? Jamison W123 E,CE,D,CD,TD,TE Class 1 05-04-2004 06:51 PM
