swap diff /8 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-16-2009, 08:42 AM Thread Starter
Date registered: Feb 2008
Vehicle: Mercedes Benz Clk 200 Komp cabrio
swap diff /8
I to swap my diff is broken, but i need some longer bigger final. help:bowdow n:
tiago850 is offline
post #2 of 5 (permalink) Old 04-16-2009, 12:00 PM
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1973 W115 200 /8
Which /8 do you have ?
Is it a 4cyl, a 6cyl, a diesel ?
Do you have automatic or manual gears ?
There are several rear differensials to choose from.. But first you have to know wich final gear you have today..
1991 W140 400 SE - SOLD !!
1973 W115 200 -For sale as project.
Eirik 400 SE is offline
post #3 of 5 (permalink) Old 04-19-2009, 02:00 PM Thread Starter
re
my is the w115 3000cc diesel 6 cil 4 speed gearbox but i want to put a diff that make de revs go down at the same speed
tiago850 is offline
post #4 of 5 (permalink) Old 04-19-2009, 02:25 PM
Date registered: Apr 2009
As far as i'm aware you can swop in the whole rear end from a W107 SL or SLC and as they came with big V8's i'm sure they'll have lower ratios available, LSD on some of em too, not sure if the diff can be swopped alone though, you'd need to check driveshafts and propshaft fitting.
popuptoaster is offline
post #5 of 5 (permalink) Old 04-27-2009, 05:29 AM
mbkomfort's Avatar
Vehicle: -88 250D, -93 280TE-24 Sportline and -00 E270T CDI
You could use a W123 300TDT rear end, but a turbo-diesel diff is maybe hard to find where you live? you could allso use a W126 (80-85) or a W116 diff. Check what is available on the used parts market and post back
mbkomfort is offline
Swap a factory diff to make a 560 go faster? cascade W126 S,SE,SEC,SEL,SD,SDL Class 148 08-30-2010 11:13 AM
Misc. Questions - Redline - Shift Points - Gen II 560 Diff Swap JMPhotography W126 S,SE,SEC,SEL,SD,SDL Class 8 01-05-2009 05:34 PM
Need input on 126 Gen 1 diff swap options. johnhef W126 S,SE,SEC,SEL,SD,SDL Class 25 12-02-2008 09:16 PM
w124 E420 transmission problem after diff swap jmang09 W124 E,CE,D,TD Class 10 10-10-2008 08:51 AM
diff swap: what do i have? NüR-SPEC W126 S,SE,SEC,SEL,SD,SDL Class 29 07-27-2007 04:48 PM
