59 220se hood cable - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 04-14-2009, 02:16 PM Thread Starter
Date registered: Mar 2009
59 220se hood cable
Ok I'm trying to put the hood cable back in and can't figure out how the thing goes in.I know the path it takes and how each end goes on but the problem is that the cable passes threw the core support and the hole is only a little bigger than the cable.Which end comes off and how?
Redpawn is offline
post #2 of 7 (permalink) Old 04-14-2009, 05:25 PM
wbain's Avatar
Date registered: Dec 2003
Quoted: 4 Post(s)
W111 Fintail or Ponton?
wbain is offline
post #3 of 7 (permalink) Old 04-15-2009, 04:12 AM Thread Starter
ponton
Redpawn is offline
post #4 of 7 (permalink) Old 04-15-2009, 12:23 PM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
The "T" pull unscrews off the cab end if memory serves me correctly. Lock nut on back.
Ed Mclass is offline
post #5 of 7 (permalink) Old 04-15-2009, 04:01 PM Thread Starter
I Had already taken the handel off and it stil didn't fit.The I figured out the
problem at some point some one put a new core support in and the hole in the support was to small.All the other cars like this one we have here have a larger hole to allow the end with the handel(handle removed) to slide threw.
Drilled the hole to the correct size and the cable when't right in.
Redpawn is offline
post #6 of 7 (permalink) Old 04-16-2009, 01:34 PM
Ed Mclass's Avatar
Glad you figured it out. Have fun driving it now! Also check out Mercedes-Benz Pontons (1953-1962) © www.mbzponton.org.
post #7 of 7 (permalink) Old 04-20-2009, 09:50 AM Thread Starter
It's still a long way from driving.I'm just doing what ever I can to it while waiting for the engine parts to come back from the machine shop.
Redpawn is offline
Hood Release Cable Broke...Can't Open Hood..Help! NRMl430 W163 M-Class 53 03-19-2015 08:41 AM
Broken Hood Cable On '84 SD jakeliefer W126 S,SE,SEC,SEL,SD,SDL Class 4 02-23-2009 08:53 PM
Hood Release Cable MBGraham R/C107 SL/SLC Class 1 06-14-2008 12:52 PM
broken hood cable?? andrew_falky W126 S,SE,SEC,SEL,SD,SDL Class 2 09-18-2005 01:52 PM
hood cable disconnect kreuser914 W201 190-Class 3 02-15-2005 06:36 AM
