Proper vacuum gauge readings - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 04-11-2009, 06:32 AM Thread Starter
Date registered: Apr 2009
I have an '84 300td that shifts with a "thump" when I come to a stop so I replaced the vacuum connections and worn levers on the 3 way vacuum fitting. The problem still exists. With the engine running the vacuum gauge from the supply lines gives me a reading of 20-22. The reading I get from the supply side that connects to the green dashpot is zero. That makes no sense to me when I get a reading from all the other connectors. Why am I not getting a reading that feeds to the dashpot? Would this be why the car shifts so hard?
I'm a newbie to vacuum testing.
marf9 is offline
    ECONOMY vacuum gauge indicator velu786 W124 E,CE,D,TD Class 0 03-29-2008 11:04 AM
    Oil Pressure Gauge readings Spencer A W124 E,CE,D,TD Class 1 10-18-2007 09:50 PM
    Incorrect readings on gas gauge mike_t W220 S-Class 8 04-20-2006 06:57 AM
    "normal" engine vacuum and timing readings for a 250C? Riquiscott Vintage Mercedes-Benz 0 09-01-2005 08:54 PM
    PROPER A/C READINGS... 89_190e_2.6 W201 190-Class 2 06-26-2004 09:45 PM
