1970 250C, value, popularity,etc. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-02-2009, 09:21 AM Thread Starter
Date registered: Mar 2009
Yes, more questions from a newb to the Benzworld. I have recently purchased the fore mentioned car 2dr.no sunroof. It has the 2.8 with a 4spd. Very solid car overall, a little surface rust on bottum of front fenders, and sun baking on hood, roof, trunk. Interior is propbably a 7/10. Exterior bone white, interior red leather. I paid $3200.can. Problem is, after driving it home, I found the knock in the bottum end, had mechanic over to listen, figures rod bearing.
My questions for you all "in the know" are; Is this model popular/rare? Is it worth dumping $$ into? Or should I sell as is and cut my losses? THank you for your opinions.
CanadianMark is offline
post #2 of 4 (permalink) Old 04-02-2009, 10:33 AM
christopher1959's Avatar
Date registered: Jul 2007
Vehicle: 1990 Mercedes 300TE Estate Wagon 3.0L 208K miles Smoke Silver/Cream Beige Tex. and others.
That would be a 280C. then not a 250c,, First of all, how bad is the knock? If not too bad, just drive it till it gets really loud, which will most likley take a long time,, these engines are tough as nails and a little bottom end noise is not unusual on any 40 year old inline 6 cyl. they have long crankshafts and whip around. Drive and enjoy,,,
1990 S-124 3.0 Sport Touring Wagen. 218K + Miles
1987 Porsche 911 Carrera 3.2 53K miles !
1971 BMW 2002
1987 BMW 325 IS M-tech
1976 Jaguar XJ12C 5.3 V12 Coupe
2009 Suzuki GZ250
And Remember to always KISS, Keep It Simple Stupid!
christopher1959 is offline
post #3 of 4 (permalink) Old 04-02-2009, 10:44 AM Thread Starter
The knock isn't really terribly bad. It is not a consistant bang, and is only appearant at certain rpms. Maybe I will pump it full of Lucus oil and see how far she takes me. From the costs of a rebuild up here,(quoates of $9000), I might as well blow this one and buy a long block...
post #4 of 4 (permalink) Old 04-04-2009, 12:07 PM
Date registered: Apr 2008
Quoted: 2 Post(s)
The 250C has an in-line single overhead cam six with a bulbous single valve cover. The spark plugs are on the driver's side. The 280C is a dual overhead cam in-line six with a relatively flat "dual" one piece valve cover. The spark plugs are located on top between the cams. Can you isolate whether it is a top end or bottom end noise? The lower end noise is very uncommon, and as said above, they're pretty bulletproof. More common are top end problems caused by oil starvation. Bottom end noise will be at engine RPM and come and go in intensity with slight throttle movement. The noises will be more like dull, relatively low pitched thuds, maybe accompanied by slight vibration. Your oil pressure also may by lower than the high normal of these MB's. The top end noise is half engine RPM (slower), more typical, and be a higher pitched tapping or knocking. This may or may not be continuous, and not generally affected too much by throttle movement. Take off the oil filler cap and check for fresh oil wetness, and note if there is an abundance of sludge. If so, the top end oil feed holes may be plugged or restricted. This is common when oil is not changed regularly and/or repeated overheating. Also, the newer oils are much better than the oils of this vehicle's era, so much of this type damage may occur over many years of less than adequate preventive maintenance. Let us know what you find.
They're not "rare", but there are not too many "really nice" ones around. What is the condition of the rest of the vehicle? How well do YOU like it? I've had my 280C for 23 years, and I don't care what "stated book or average" value is. I love it, and will probably hand it down to one of my sons like I did my 250S. I did put the stipulation on the 280S that it goes to his son when he is done with it, as I got from my mom when my dad passed away in 1990, and he bought it new. The April 2009 Old Cars Price Guide shows the '70 250C shows a price range from junk ($700) to pristine ($17000), and a comparable several year newer 280C up to $18000. Hope this helps.
mbbuff is offline
    1970 250C Knocking.... CanadianMark Vintage Mercedes-Benz 2 04-01-2009 11:32 AM
    New Member - Just bought 1970 250C NewWilOrder General Mercedes-Benz 0 09-11-2008 01:22 PM
    Very unusual 1970 250C Gazolba Vintage Mercedes-Benz 4 03-07-2007 02:41 PM
    turbocharging a 1970 250C joshdvirnak Vintage Mercedes-Benz 0 05-01-2005 07:36 PM
    1970 250c Transmission Probs dosoakies Vintage Mercedes-Benz 1 02-05-2004 06:59 PM
