1970 250C Knocking.... - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-31-2009, 06:32 PM Thread Starter
Date registered: Mar 2009
Yes, I am new to the Benz and Benzworld, (previously a VW restorer). But I have bought a 250c today and of course when looking at it and test driving it everything was perfect....drove it home, about an hour +/-, and now she knocks at odd RPMs. Not really consistant either, just once in a while I get a rattle out her. Any Ideas? I am really hoping it is not a connecting rod bearing, but that is where I am leaning at the moment. Thanks for your time.
CanadianMark is offline
post #2 of 3 (permalink) Old 04-01-2009, 09:33 AM
Oil pressure relates to rod knocks, hot idle should be greater than 15psi
Brian O
bostosh is offline
post #3 of 3 (permalink) Old 04-01-2009, 10:32 AM
TFIO's Avatar
Date registered: Feb 2009
Vehicle: 57 and 61 Ponton's 1969 220
First off, is it a rattle or a knock? Is it a knock sound with a deep tone, like a larger part? More of a tap, or somewhere in the middle? The deeper sound could be a rod bearing at the crank. In the middle sometimes is a wrist pin. Since you say it is not constant or at the same rpm and you said "rattle", the valve train could be suspect in my opinion. If you can get it to make the noise in your driveway you can use a mechanics stethascope (SP?), or a long screwdriver with your ear to it to isolate the source (Old mechanics trick, and I would urge extreme caution doing either of these) you will be amazed at what you can diagnose with this method.
Good luck.
TFIO is offline
    Looking for 1970 250C W114 Parts joshes For Sale/Wanted/Trade/Giveaway 3 07-19-2011 12:06 PM
    New Member - Just bought 1970 250C NewWilOrder General Mercedes-Benz 0 09-11-2008 12:22 PM
    Very unusual 1970 250C Gazolba Vintage Mercedes-Benz 4 03-07-2007 01:41 PM
    turbocharging a 1970 250C joshdvirnak Vintage Mercedes-Benz 0 05-01-2005 06:36 PM
    1970 250c Transmission Probs dosoakies Vintage Mercedes-Benz 1 02-05-2004 05:59 PM
