71 250 Backfires doesn't start - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-24-2009, 11:11 PM Thread Starter
Amoosbenz's Avatar
Date registered: Jun 2008
Vehicle: 1971 250 1988 420SEL
Hello
MY 1971 250 has been back firing latly specially when its cold sometimes between 30-40 mph and other times between 50-60 when it warms up it runs preety decent... Any ideas? Also if the car is sitting for a more then a couple of hours I need to spray starting fluid into the carb to get it going. I am preety sure that the car is going to need a vacume advance anybody know where the part number is located so I can order it?
Thank you
Amoosbenz is offline
post #2 of 4 (permalink) Old 03-25-2009, 07:32 AM
mbkomfort's Avatar
Date registered: Jan 2008
Vehicle: -88 250D, -93 280TE-24 Sportline and -00 E270T CDI
How is your contact breaker points and other ignition components? Sure they are 100% OK?
Good luck!
mbkomfort is offline
post #3 of 4 (permalink) Old 04-08-2009, 06:03 PM
Date registered: Apr 2008
Quoted: 2 Post(s)
Is it backfiring up through the carb. or out the exhaust? As stated above, check the ignition completely...plugs, points and point setting/condenser, wires, cap, rotor and ignition timing. While you have the plugs out, you may also want to do a compression check, just for reference info. sake. A bad vacuum advance canister would not likely cause this, unless you are extremely lean for some reason to begin with. (You can check the canister with a hand vacuum pump.) Then it would "pop" back through the carb. Also, since most of the "backfiring" happens when cold, check for proper choke setting and freedom of operation. No, or too little choke when cold could cause stumbling, stalling, or popping back through the carb. Could also be a valve (intake or exhaust) that's bad or out of adjustment. Having to spray the carb. after sitting a while is a little more interesting??? When it finally starts, is there black smoke from the exhaust? Does it "chug, chug" when it first fires. Both these indicate richness, perhaps due to internal leak in carb., improper float adjustment, bad float, leaking needle and seat, etc. Also, if this were the case, you normally would not have to use starting fluid to start, just hold accelerator to the floor (do not pump) while cranking. IMO, try this first and see if it will start when doing this. If your starting fluid is ether or lacquer thinner based stuff, it might aid the hot start, even if flooded. Another thing to check for is other vacuum leaks. This could cause leaness, but in this case you should still be able to start it without fluid...just a couple pumps of the accelerator. I think I'd verify and make sure the ignition is working properly first, and then see where you're at after that. Good luck and keep us posted.
mbbuff is offline
post #4 of 4 (permalink) Old 04-09-2009, 03:50 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
How is the timing set? Has anyone removed and re-installed the distributor?
Ed Mclass is offline
    C 250 d wont start steve e class limo W202 C-Class 4 11-02-2010 04:07 AM
    MB 250 C Turbo diesel doesnt start. los1950 W202 C-Class 1 10-01-2009 05:46 AM
    My 250 petrol won't start DreczlA W123 E,CE,D,CD,TD,TE Class 12 12-11-2006 07:12 AM
    250 SE 108 hard to start cold Darren 1 Vintage Mercedes-Benz 7 10-17-2005 03:07 AM
    1990 560SEC Backfires when trying to start mikesmerc W126 S,SE,SEC,SEL,SD,SDL Class 2 11-25-2004 12:38 PM
