1984 300d advice needed, Halfshafts/cv joints - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-22-2009, 10:28 AM Thread Starter
Date registered: Mar 2009
Hello.
I recently purchased a 1984 300d, I am not so familiar with IRS so I was hoping to get a little advice about diagnosing a speed sensitive vibration issue.
I get a clunking and vibration that feels like it is coming from the rear end, mostly at freeway speeds but sometimes slower as well. The clunk and vibration are worse when I am accelerating or under heavier load. The problem appears to be worse when I am turning right, ie, when the left side suspension is loaded and the right side is unloaded.
The problem comes and goes. It gets worse when I am traveling South (yeah, I know...) or when I have driven about 100 miles, stopped for half an hour or so and then resume traveling. I have inspected the driveshaft and the flex couplings, universal joint and carrier bearing all appear to be fine. The CV boots are intact though a bit cracked. I pushed and pulled on the shafts, there is no play detectable but an interesting difference between the two sides: the right side slides in and out easily, with or without the weight of the car on it. The left side slides in and out when the car is up on jacks only. I pulled back the boot on the inside of the right side cv and the play is occurring on the diff side of the joint, which appears fine if a bit dry.
Does anyone have any advice about diagnosing this problem? Please email me off list tanjent@sbcglobal.net
Thank you
tanjenttt is offline
post #2 of 2 (permalink) Old 03-25-2009, 07:09 AM
mbkomfort's Avatar
Date registered: Jan 2008
Vehicle: -88 250D, -93 280TE-24 Sportline and -00 E270T CDI
Hello and welcome, i suggest checking out the W123 part of this forum Your car is a Mercedes W123 series.
W123 E,CE,D,CD,TD,TE Class - Benzworld.org - Mercedes Benz Discussion Forum
CV's last very very long if the boots are ok and filled with grease.
Did you jack up the rear and check the wheel bearings?
Good luck!
mbkomfort is offline
    1984 300sd cross member same as 1984 300d petecooke W126 S,SE,SEC,SEL,SD,SDL Class 4 02-16-2009 05:09 PM
    1984 300D jerryinva General Mercedes-Benz 2 02-06-2009 06:51 PM
    Advice needed on 300D diesel_fan W124 E,CE,D,TD Class 0 09-27-2008 12:47 PM
    1984 US model 300d vs 1984 euro 300d? DieselKraut W123 E,CE,D,CD,TD,TE Class 7 05-10-2006 10:00 PM
    Need some advice on shocks/ball joints... LeCorbusier R170 SLK-Class 5 03-19-2005 12:42 PM
