power window relay - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-21-2009, 10:48 AM Thread Starter
Rauchen's Avatar
Date registered: Jul 2008
Vehicle: 1971 Mercedes 280sel (w108)
power window relay
I have a 1971 w108. I don't use the windows cause the driver side needs a regulator. When I tried, though, to operate the others, they didn't work. I'm figuring that it is because of a bad relay. I know the relay is back by the firewall on the passenger side, but I'm not sure which one it is. There seems to be about three relays there plus two fuse holders. Does anyone know which one it is specifically?
Rauchen is offline
post #2 of 2 (permalink) Old 03-21-2009, 02:02 PM
Date registered: Mar 2009
Vehicle: 1970 280se
You can get a new regulator at the below website,as for the relay they have them also.Your best bet would be to get a 12v light up tester and test across all the relays,have another person hit the window switch and see if you can get a light up and if your actually having relay problems, or it could be the window motor. I picked up a 6,12,24v dc mini tester at kragens for like 3-4$ it has saved me alot of trouble with electronics
window regulator
window motor
1970280benz is offline
    Power window relay B71ZZZ W124 E,CE,D,TD Class 11 02-26-2009 09:24 AM
    2000 W210 Power window motor/regulator/relay? tresean1 W210 E-Class 7 01-03-2009 09:42 AM
    Where is power window relay for 300D? Dave300D W123 E,CE,D,CD,TD,TE Class 2 07-28-2008 03:29 PM
    power window relay nedredbeard Vintage Mercedes-Benz 7 07-12-2007 03:35 PM
    window relay zulumack W126 S,SE,SEC,SEL,SD,SDL Class 3 07-11-2006 08:04 PM
