1973 w114 280c how to change shift knob - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-14-2009, 06:04 AM Thread Starter
Date registered: Jan 2008
Need to change automatic shift knob to classy wood. New has shaft, so looks like have to change at base of shaft. Tx much.
hisnibs is offline
post #2 of 3 (permalink) Old 03-17-2009, 12:52 AM
mbkomfort's Avatar
Vehicle: -88 250D, -93 280TE-24 Sportline and -00 E270T CDI
Hi! Remove the trim piece sorrounding the gearchange assembly, unbolt the part with the "PRNDSL" gate and lift it up a little, and loosen the locking nut on the gear knob rod with a 13mm open end spanner..
Gear lever must be properly aligned when finished, gear lever out of position can make trouble for the automatic transmission.
So when finished check that when you are in "D" you have no tension on the lever, you should have 1-2mm clearance in front of the shaft in the "DS" part of the gate.
And check the other forum threads in the bottom of this page
mbkomfort is offline
post #3 of 3 (permalink) Old 03-20-2009, 09:17 AM Thread Starter
Thanks much for the help.
hisnibs is offline
W114 shift knob removal feerocknok Vintage Mercedes-Benz 2 02-10-2009 11:48 AM
1973 280C(W114) Throtle linkage markelenasmith11 Vintage Mercedes-Benz 1 07-12-2008 02:56 PM
How do you change the shift knob???? mbghost W124 E,CE,D,TD Class 2 06-02-2003 11:57 PM
In order to change the shift knob, how to pull way the shift knob leather?? Marcello (Piacenza - R170 SLK-Class 7 04-22-2002 10:26 AM
Anyone knows how to change the shift knob?? Strax R170 SLK-Class 1 01-06-2001 05:45 PM
