Question on W111 14" wheel clearance/fit - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-07-2009, 05:00 PM Thread Starter
10kpharo's Avatar
Date registered: Mar 2009
Vehicle: 1982 380SL/1955 Austin A30/2014 VW Beetle convertible/2005 Honda CRV/1964 Mobylette moped
Hi, I'm looking at a 1965 W111 220SEb. It's on the original 13" rims. For an additional $1,400 the seller will include a set of 14" Bundts with new tires. Do the 14" Bundts bolt on directly without any fender clearance issues and/or need for spacers?
10kpharo is offline
post #2 of 3 (permalink) Old 03-07-2009, 05:57 PM
ouch that price
Take it with the 13"s and keep them.
Tirerack-dot-com has the 185-70 x 13
Bundts $35-50 each x 5
205-70x14 Pep boys $300
I have had 205-70 x 15" Bundts on my 220SEb. fit close but fit with no problems, I had the rear axle rubber locating parts new.
There was less than a finger width between rear wheel well and tire, no rubbing
Brian O
bostosh is offline
post #3 of 3 (permalink) Old 03-09-2009, 09:52 AM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
I have fitted R129 600SL 16X8 chromed flat face alloys with 225/55/16 tires to my 111 coupe and they fit just fine(after some trial and error with the offset)
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
    can i fit a 20" wheel? kevman05 C209/A209 CLK-Class 10 03-09-2009 01:24 PM
    Can you fit a 11" wheel under a SLK? jwrape R170 SLK-Class 17 04-22-2008 04:58 AM
    Wheel Fit Question Wizz190E W201 190-Class 4 03-16-2007 06:57 PM
    will 285/30/19 tire fit a 19x8.5 wheel? Will it fit? Fender clearance problems?? spine911 W210 E-Class 1 11-03-2004 04:46 PM
    18" wheel clearance Guest (MBNZ) General Mercedes-Benz 3 02-11-2002 06:00 PM
