Backwards distributer? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-07-2009, 01:07 PM Thread Starter
Rauchen's Avatar
Date registered: Jul 2008
Vehicle: 1971 Mercedes 280sel (w108)
I've noticed that my timing (according to my light) is off. But the closer I try to get it to TDC the worse it gets. My Haynes book talks about adjusting the vacuum advance. I looked and mine has no adjusting bolt. Then comparing mine to pictures that I have seen, the vacuum advance seems to be pointing the wrong way. The pics I have seen show the advance pointing toward the radiator. Mine points toward the battery. The Haynes manual also talks about some distributors having a notch that you line up with the #1 spark plug. Mine has that notch and it is lined up toward the #1 plug. I am assuming that this is a distributor off of another model of Mercedes, but I am wondering if I am going to ruin something by leaving it as is. The car runs good. Starts easy, responsive, not as much torque as I think it should have, but it also no longer has the FI set up. It has an SU carb on the FI intake. Here are some pics of the distributor and carb. Any advice would be appreciated, cause I'm at a loss.[IMG][/IMG
Rauchen is offline
    fuel distributer recomendation baido R/C107 SL/SLC Class 0 01-27-2009 12:45 PM
    Little black box on fuel distributer mercedes_4_ladies W126 S,SE,SEC,SEL,SD,SDL Class 7 04-11-2007 09:39 PM
    Fuel Distributer rebuild ? James A. Jeffery R/C107 SL/SLC Class 1 04-11-2007 12:44 PM
    Distributer or Carburetor? Haroundb W123 E,CE,D,CD,TD,TE Class 2 12-09-2006 05:18 PM
    Fuel Distributer / One Cylinder not firing ronl10 W201 190-Class 0 12-19-2005 05:00 AM
