what kind of oil should I use ???? - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 02-25-2009, 02:29 PM Thread Starter
firstbenz250s's Avatar
Date registered: Feb 2009
Vehicle: 1967 250S
Howdy all just asking what kind of oil to use on my 1967 250s ? Thanks for stopping
"It's made in Germany and you know them German's make good stuff! "
firstbenz250s is offline
post #2 of 16 (permalink) Old 02-26-2009, 08:36 AM Thread Starter
Vehicle: 1967 250S
cant find in book any help
post #3 of 16 (permalink) Old 02-26-2009, 12:02 PM
diametricalbenz's Avatar
Date registered: Oct 2005
Vehicle: '77 6.9, 74 240D, 96 Ram 5.9L Cummins, 02 Civic EX, 10 Mazda 5 Sport
Quoted: 4 Post(s)
Everyone has different opinions but any name brand 20-50W oil should be fine. Just don't change brands repetitvely.
1977 - W116 - 6.9
1974 - W115 - 240D /8 - 4(M) OM617.910 + Turbo + 300D FW - Completed 7/8/10
diametricalbenz is offline
post #4 of 16 (permalink) Old 02-26-2009, 03:27 PM Thread Starter
Vehicle: 1967 250S
thanks do you think 10-40 would be fine?
post #5 of 16 (permalink) Old 02-27-2009, 01:24 AM
BenzWorld Elitist
Marsden's Avatar
Vehicle: Mercedes-Benz
Quoted: 464 Post(s)
It depends on the condition of your engine. The rationale behind the heavier-weight oil, particularly for an old and/or worn engine, is that the engine's internal clearances have expanded such that more viscosity is required to produce the same or similar oil pressure.
However, as you live in Michigan I'd also want to know if and how often you start your car in extremely cold weather. The higher weight oil makes cranking slightly more difficult in extreme cold and even creates more difficulty for the oil exploring the engine's entire set of passages in the first several seconds of running. This carries negative implications with respect to internal wear.
For this reason, some people in less temperate zones switch weight with the season. In summertime, with certain cars, I've actually run straight 40-weight oil because I didn't trust the multi-viscosity ratings. But that was then, this is now--oils have improved over the years.
Long way of saying, you're probably fine with either weight, particularly if you keep your car in a heated garage. How is the oil pressure reading?
Marsden is offline
post #6 of 16 (permalink) Old 02-27-2009, 05:12 AM Thread Starter
Vehicle: 1967 250S
well since i just got the car it was kept in a garage engine sounds good no drips or spots on my floor or the guy garage floor i got the car from but old engine looks very well kept like the rest of car and I dont have any plans on driving in the cold however the oil in engine now is real black and pressure read high when starting
post #7 of 16 (permalink) Old 02-27-2009, 03:27 PM
BenzWorld Elitist
Marsden's Avatar
Quoted: 464 Post(s)
Congrats on getting your hands on a well-cared-for 250S! Now change the oil & filter! Either weight is fine; all other things being equal I'd probably go with the 20W50 as long as I wasn't going to start it in subfreezing weather too much. How's the pressure when you're warmed up and driving along? That's the real measure. Anyway congrats
Marsden is offline
post #8 of 16 (permalink) Old 02-27-2009, 03:40 PM Thread Starter
Vehicle: 1967 250S
thanks
well I cant get her to stay running any ideas ?? old (2nd)owner said I may have to adjust the carbs
Here she is
post #9 of 16 (permalink) Old 02-28-2009, 02:19 PM
BenzWorld Elitist
Marsden's Avatar
Quoted: 464 Post(s)
Hard to diagnose cars over the internet but fuel supply would definitely be one of the first things I'd look at.
Marsden is offline
post #10 of 16 (permalink) Old 03-01-2009, 06:36 AM Thread Starter
Vehicle: 1967 250S
    what kind of oil are you using in your C-class? benz rider W202 C-Class 20 08-13-2007 04:35 AM
    What Kind Of Oil/ Filter Are You Using ? Hary Gahtoe C208/A208 CLK-Class 7 03-09-2007 12:36 AM
    what kind of oil?? 96S320. W140 S-Class 5 08-08-2004 05:19 PM
    what kind of oil to use? Schnell944 W123 E,CE,D,CD,TD,TE Class 12 05-23-2004 05:44 AM
    What kind of oil for 300SD? Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 4 02-04-2002 11:56 PM
