W114 Engine change - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-23-2009, 02:42 PM Thread Starter
Date registered: Dec 2007
Vehicle: 2000 Slk230 Limited Edition
W114 Engine change
I am looking into buying a 1970 250 and was wondering if anybody has put a different engine in these cars, maybe a newer benz engine or other make. Thanks in advance.
zlaja230 is offline
post #2 of 4 (permalink) Old 02-24-2009, 12:06 PM
Date registered: Dec 2008
Chevy Small block has been done. Real tight fit on the driverside for exhaust manifold clearance.
feerocknok is offline
post #3 of 4 (permalink) Old 02-24-2009, 02:53 PM
Vehicle: 2005 C350, 2002 ML270CDI, 1969 230S, previously 2002 A160, 1985 380SEC ivory, 1983 380SEC grey
Hi zlaja,
I presently have a W114-010, ie an early model, which started out with a 250 engine, and now has a 280 (M130) engine. This is its 3rd engine, as the engine number on its data card is different to that on its registration papers, which in turn is different to the engine actually in the car!
I understand that the newer 280 engine (M110) is very difficult to fit into earlier body shells because there were two diagonal stiffening struts from the fire wall to the side chassis members and the DOHC cover is too high and too wide.
Of course there are the usual problems matching up the accessories such as power steering, air conditioning, auto transmission, oil cooler, etc.
Keep lookingh
regards from Down Under (Australia)
Audiophile_AU is offline
post #4 of 4 (permalink) Old 03-04-2009, 12:09 PM
redwood's Avatar
Date registered: Dec 2004
Vehicle: 500E, E320, 190E, E55
Quoted: 13 Post(s)
What's wrong w/the original engine? They are very durable and easily rebuilt. bottom end will live forever if maintained properly. why not add a dual carb setup from the S this will surely spice up performance and make it more enjoyable. please let us know what you find..
E320 3.2 W211
E55 5.5 W211
500E 5.0 W124
190E 2.3 W201
redwood is offline
    w114 engine miss trevortrumpet Vintage Mercedes-Benz 2 08-30-2008 02:23 PM
    74 280C engine swap? w114 to V8? or other? FastKatanaBoy Vintage Mercedes-Benz 2 03-11-2008 03:49 PM
    W114 and a 250D engine?? Odrec Vintage Mercedes-Benz 14 10-17-2006 11:11 AM
    W114 71 250 Engine Question AndyD Vintage Mercedes-Benz 2 10-03-2006 07:40 AM
    W114 engine help needed. Cam Vintage Mercedes-Benz 6 02-04-2005 02:02 AM
