1974 450sl voltage regulator - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-18-2009, 09:48 PM Thread Starter
Date registered: Aug 2007
Post 1974 450sl voltage regulator
Where is the voltage regulator in my 1974 450sl? If I buy a new alternator with a regulator in it, what do I do with the existing voltage regulator? How do I strap it out? Thanks
ricardito is offline
post #2 of 3 (permalink) Old 02-19-2009, 05:06 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
Just run the heavy lead from the alternator to the large terminal on the three terminal block. that is the main battery charging lead. On the regulator there are three wires. Unpick the insulation so you expose the blue wire. That is the charging light wire,connect it to the small terminal on the rear of your new alternator. The other two wires are now redundant. Remove the regulator and put it away somewhere safe.
If you are going from the standard W107 alternator to a larger capacity alternator you MUST run a new main wire of larger diameter to the terminal block. If you use the original smaller wire it will fry!
mercmad6.3 is offline
post #3 of 3 (permalink) Old 02-19-2009, 08:02 AM Thread Starter
Thanks very much, that was a big help!
    1974 450SL Guest (MBNZ) R/C107 SL/SLC Class 5 06-17-2011 07:57 AM
    Voltage regulator? marrymemercedes R129 SL-Class 2 05-29-2007 07:03 AM
    Fs: 1974 450sl TheJackal3006 For Sale/Wanted/Trade/Giveaway 0 05-31-2006 06:39 PM
    Voltage Regulator Indiana Drew G-Class 9 01-16-2006 10:12 AM
    1974 450SL Guest (MBNZ) General Mercedes-Benz 1 07-17-2001 09:08 AM
