Leeds on Voltage regulator m189 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-11-2009, 10:10 PM Thread Starter
67 300's Avatar
Date registered: Oct 2008
Vehicle: 73 450 SE Euro
Unhappy Leeds on Voltage regulator m189
Looking for a regulator to fit car any numbers I can cross reference or parts houses where I can find one.
67 300 is offline
post #2 of 2 (permalink) Old 02-12-2009, 07:50 AM
Any Delco-Remy (General Motors standard) voltage regulator from the pre-alternator days 50-60's will mount correctly and function perfectly.
The trick is to swap the positions of the #1 and #3 terminals from the Bosch (expensive well built) unit to the Delco.(cheapo) unit. #2 is #2 no change.
Look up an old Delco wiring chart and an old Mercedes = same charging and starting system.
Interesting huh?
The early brake systems internal parts were inches.
Tires world over are inches.
Brian O
bostosh is offline
    Voltage Regulator amccune W123 E,CE,D,CD,TD,TE Class 4 08-29-2008 05:46 PM
    voltage regulator dougf General Mercedes-Benz 7 06-01-2007 07:24 AM
    Voltage regulator? marrymemercedes R129 SL-Class 2 05-29-2007 06:03 AM
    Voltage Regulator rsullivan222 W140 S-Class 8 01-25-2006 01:39 PM
    Voltage Regulator Indiana Drew G-Class 9 01-16-2006 09:12 AM
