280SE fuel injection pump overhaul - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-10-2009, 08:46 PM Thread Starter
Date registered: Feb 2009
After letting my '69 280SE cab lay up for over a year (I know - bad, bad) it will not run. There is just a marginal amount of fuel output from #4 and #5 spigots. I have confirmed adequate fuel pressure and we got it to chug a bit by hotwiring the cold start solenoid. The pisser is that I had the pump rebuilt ($900!!) just a couple of years ago. can anyone offer advice on what to do now or does anyone know of a pump builder who specializes in these and lives on the Northeast - I'm hoping to find the guy who did the original overhaul to see if he can help me out now - I lost his name and receipt (I know - bad, bad). Thanks!
jbirdga is offline
post #2 of 6 (permalink) Old 02-10-2009, 08:57 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 661 Post(s)
Gasoline injection pump rebuilders are a rare breed these days. We get $1395 exchange for our rebuilt units. There was a guy in the NE a couple years ago, but he has effectively retired.
GeeS is offline
post #3 of 6 (permalink) Old 02-10-2009, 10:35 PM
try this maybe?
Carefully remove side cover and check to see if the rack moves freely for the total travel. You must hold the lever and governor at max.
Then flush the entire unit with carb cleaner, then follow with ATF,
The rack must move on its own with NO resistance.
Hopefully that may do it,
Check for particles in the fuel filter can by dumping the contents out through a white paper towel pack (4)
If so, a particulate clog will be trouble.
Also you can check each stump on the MFI by disconnecting and cranking engine. those can really squirt if everything is correct.
UH do I need to say disconnect the sparking system before that?
OR just let someone else do this for $85 an hour.
Brian O
bostosh is offline
post #4 of 6 (permalink) Old 02-11-2009, 10:01 AM
Date registered: Jul 2006
Vehicle: 16v 5sp;500e wagon ;w109/3.5,6.3;560SEL;500SELAMG;500SECAMG;500SLAMG 5-sp;993 C4S;Z3Mcoupe;others
Quoted: 13 Post(s)
Hans
Hans Utke
H&R Fuel Injection
Bohemia, NY Long Island
He is not retired, very helpful. He rebuilt my pump and cold start valves in my 6.3 which came out perfect.
The price I believe was 1300 for a complete overhaul with show detail.
1970 Mercedes 300SEL 6.3
1971 Mercedes 300SEL 3.5
1976 Chrysler Town & Country
1977 BMW 530i Callaway Turbo
1992 Jolf - Custom MK2
1993 Mistubishi Eclipse GSX
1997 Porsche C4S
2001 BMW Z3 M Coupe Laguna Seca Blue/Laguna Seca Blue
1982 Mercedes 500SL AMG 5sp
1984 Mercedes 500SEC AMG 199/Mushroom
1985 Mercedes 500SEL AMG Black/Palomino
1985 Mercedes 500SEL AMG Anthracite/Mushroom
1987 Mercedes 560SEL 040/Black
1987 Mercedes 190e 2.3-16 5sp 199
1993 Mercedes 500e 199/Mushroom
kmukherjee is offline
post #5 of 6 (permalink) Old 02-11-2009, 10:18 AM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 661 Post(s)
H&R is one of the few left (another in CA), but the fellow who retired is/was in New England.
GeeS is offline
post #6 of 6 (permalink) Old 03-20-2009, 02:17 PM
Date registered: Mar 2009
Vehicle: 1970 280se
1970280benz is offline
    Fuel Injection Pump 220SEBC Vintage Mercedes-Benz 10 09-13-2008 03:16 PM
    Fuel Injection Pump cchkaiban W123 E,CE,D,CD,TD,TE Class 3 04-09-2007 07:43 PM
    fuel injection 72 280se 4.5 tukey Vintage Mercedes-Benz 5 11-20-2006 11:51 PM
    Fuel filter before or after fuel pump on 1972 280SE? Floydf Vintage Mercedes-Benz 6 10-19-2006 10:09 AM
    metal fuel line CIS fuel injection 79 280se w116 rfitts46 W116 S, SE, SEL, SD Class 0 01-28-2006 03:37 PM
