18 steel wheel & Hubcaps any interest? - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 01-22-2009, 04:49 AM
bluefang's Avatar
Date registered: Mar 2007
Vehicle: 450SLC
AMG C32/S55 brakes 4/6 piston calipers will fit on your car? Do u know if they will fit on a R107, will i need to get specific rotors for them too or will the OEM slotted rotors work?
Are you sure about the 32mm offset been ok for the 107s, because atm my current wheels are 30mm and only 7" wide and they are almost touching the inside guard while still been 10mm+ away from the outer guards?
As to supercharging, all u need is a simple piggy back ECU such as what 300ce turbotechnics dyno revisit - ShopForum is using. Or go the whole hog and install a MSII.
bluefang is offline
post #12 of 16 (permalink) Old 01-22-2009, 10:48 AM Thread Starter
Date registered: Aug 2007
Vehicle: Mercedes/BMW/Ferrari
C32 Brakes fit,I made the brackets...I pulled the brakes off my 95 or 96 W124 Cab don't remember which one and made brackets then put them back on the w124.It's not a simple bolt up issue,but I can supply the brackets.
The picture with the silver AMG's I also have 32 brakes on but I kept it this way for just a few days..
My 6.9 is under reconstruction right now for a 6 speed and S55 brakes I will try and locate the pic but I can assure you it won't be soon,I have over 3000 pictures but spent most of my time actually building cars so sometimes I do something and it goes many phases without pics
ID:	216798   Click image for larger version
Name:	pictures 256-1.jpg
"I don't know anything for a fact",but have lots of opinions that might or might not pan out!
coastline is offline
post #13 of 16 (permalink) Old 01-26-2009, 01:57 AM
Date registered: Jun 2004
Quoted: 6 Post(s)
18x8 won't fit the early W107 .possibly they may fit the later R107 560SL which used a different rear end and front hub .
Fitting ther bigger brakes is easy,in fact the later brakes can be bolted to the W108 hubs with the mentioned fabbed brackets.
This is a picture of a friends car,a W107 with bigger brakes,specially made in Germany by Zimmer and if you look close it has hydro suspension.
It also has a 6.9 engine... :-)
mercmad6.3 is offline
post #14 of 16 (permalink) Old 01-27-2009, 03:42 PM
bluefang's Avatar
Vehicle: 450SLC
Hydro suspension!!!!!! What, where, how?? Was it complicated to install? How much did it cost? Is it a kit? Is it fully adjustable? More information please.
bluefang is offline
post #15 of 16 (permalink) Old 03-25-2009, 06:58 PM
Date registered: Jan 2003
Vehicle: 1977 450 SL
did you ever go through with the custom rims? any pics available?
BMarsh07 is offline
post #16 of 16 (permalink) Old 11-07-2011, 01:49 PM
Date registered: Nov 2011
18" wheels
I am restoring a 1970 280SL and I want to put 18" steel wheels on it. Please tell me where I can get them.
Joe
Motorbahn is offline
    WTD: 15in wheel trims/hubcaps - cash waiting! streetrules For Sale/Wanted/Trade/Giveaway 0 06-05-2008 03:31 PM
    wtb 300d/w123 steel wheels for hubcaps brax For Sale/Wanted/Trade/Giveaway 0 04-29-2008 07:47 PM
    FS: Wheel Hangers, stainless steel 14x1.5mm & 12 X 1.5 wbrokow1 For Sale/Wanted/Trade/Giveaway 0 10-09-2006 12:24 PM
    Check out my new, stock, hubcaps 14" steel rims!!! tiger_biru W123 E,CE,D,CD,TD,TE Class 23 07-27-2005 11:01 PM
    Bosch 115 amp alternator interest?? JR_Rider W126 S,SE,SEC,SEL,SD,SDL Class 5 04-03-2005 11:18 AM
