W115 grill swap - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-07-2008, 06:55 PM Thread Starter
Delibes's Avatar
Date registered: May 2008
Vehicle: 1977 450SEL 6.9
Quoted: 2 Post(s)
W115 grill swap
Hello there!
Just a very quick question... Would be possible to change the grill in a W115 (more specifically, a 240D) for that of a W113 (Pagoda Style)?
I am perfectly aware that both models have completely different body styles, but is this even possible to do? Would a body shop do it? How much needs to be changed to fit the grill?
Thanks!
Delibes is offline
post #2 of 6 (permalink) Old 12-08-2008, 03:24 AM
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1973 W115 200 /8
Don't think it's possible.. And wouldn't look good at all.
And also, if the look you're after is the big star in the centre of the grille, then you can't get the look you want. Because the of the height of the grille..
But you could give it a try.. On your own responsibility..
1991 W140 400 SE - SOLD !!
1973 W115 200 -For sale as project.
Eirik 400 SE is offline
post #3 of 6 (permalink) Old 12-08-2008, 03:33 AM
dseretakis's Avatar
Date registered: Nov 2006
Anything is possible. A good job would require much metal fabrication and would be very costly. It would look horrible. DON'T DO IT!
dseretakis is offline
post #4 of 6 (permalink) Old 12-08-2008, 06:27 AM Thread Starter
Delibes's Avatar
Quoted: 2 Post(s)
You mean the SL grille is taller than the w115 grille?
Does anybody have the measures of both the grille and the front of a w115 240D so I can figure it out?
Here's a photoshopped render of what I am looking for! Practically a 4-door, 30mpg Pagoda.
Thanks for your responses!
Delibes is offline
post #5 of 6 (permalink) Old 12-08-2008, 10:41 PM
Date registered: Jun 2004
Quoted: 6 Post(s)
Early 114 and 115's are higher in grill than the last of series. Your idea,like so many good pieces of inspiration has been done before on a W109.
mercmad6.3 is offline
post #6 of 6 (permalink) Old 12-10-2008, 10:10 AM Thread Starter
Delibes's Avatar
Quoted: 2 Post(s)
Originally Posted by mercmad6.3 View Post
Early 114 and 115's are higher in grill than the last of series. Your idea,like so many good pieces of inspiration has been done before on a W109.[/img]
What a beauty! Whose is it?
SL and SEC grilles with the big star in the middle (not the cheapo ones) are simply amazing... a pity they were not applied to other models until recently! I remember seeing a w124 300TD with a SEC grille and whoa, what a change!
Delibes is offline
    w115 engine swap arthrdgls Vintage Mercedes-Benz 9 03-07-2013 02:53 PM
    Swap out grill? mikefili W204 C-Class 10 02-07-2008 01:05 PM
    W115 Engine Swap arthrdgls Vintage Mercedes-Benz 3 06-12-2007 08:26 PM
    grill and star swap dboyce C208/A208 CLK-Class 0 04-29-2004 06:38 AM
    FS W115 GRILL Guest (MBNZ) General Mercedes-Benz 0 01-30-2002 03:17 PM
