74 280 Gas sedan - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-04-2008, 04:33 PM Thread Starter
Date registered: Dec 2008
74 280 Gas sedan
Hey folks,
I'm new to the site, and I have a couple of questions. I just recently came into ownership of a 1974 280 Gas Sedan, unfortunatly for me it has been sitting in a barn for the last 3 years. My question is where do I need to start to get this baby running?
ballz is offline
post #2 of 4 (permalink) Old 12-04-2008, 05:11 PM
Amoosbenz's Avatar
Date registered: Jun 2008
Vehicle: 1971 250 1988 420SEL
Was it running 3 years ago?
Amoosbenz is offline
post #3 of 4 (permalink) Old 12-04-2008, 05:20 PM Thread Starter
Yes, it was I actually drove it to the barn where it was parked, it was my grandfathers. When I got into it to load it on the trailer, it started after replacing the battery. But unfortunatly the rear brake lines blew, which I assume is from dry rot. so it will fire up. Now I would like to basically rebuild this car to make a weekend driver out of her.
ballz is offline
post #4 of 4 (permalink) Old 12-09-2008, 12:24 PM
Date registered: Dec 2004
Vehicle: 1972 280CE
Quoted: 108 Post(s)
First thing first, drain the tank and put fresh fuel in. Don't just put fresh fuel in, drain the tank first so that you get rid of any crud before it goes into the fuel system. Then check the wiring to make sure that mice have not been at them and check the fluids.
You may want to pull the valve cover off and pour a quart of oil onto the cams as they will be bone dry.
Crank the engine with the coil wire disconnected and make sure it builds oil pressure.
Then try starting.
With best regards
Check out the W114, W115 /8 enthusiast forum http://www.stroke8.org
My 280SL restoration
alabbasi is offline
    1973 280 Sedan kardar Vintage Mercedes-Benz 8 05-10-2007 06:25 PM
    FS: 1971 280 SE Sedan Shab For Sale/Wanted/Trade/Giveaway 1 11-14-2006 04:44 PM
    Different headlights for 1973 MB 280 sedan tkotanch Vintage Mercedes-Benz 3 02-26-2005 05:25 AM
    73 MB 280 Sedan engine question 74Benz280C Vintage Mercedes-Benz 3 02-18-2004 12:59 PM
    MB 280 SE sedan for sale Guest (MBNZ) General Mercedes-Benz 0 03-15-2001 02:49 PM
